valve adjustmentment screw gone, i am a danger to myself and others |
nycchef |
Jun 22 2009, 11:41 AM
mechanical moron Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
while searching for the cause of the incessent popping in my carbs, i decided to check my valves. turns out the adjustment screw for the # 4 exhaust is MISSING. i don't know how i did this having adjusted the valves last year before installing the engine. also the nuts on the rest of the rocker assembly are not 13mm , they are larger and possibly american. what the hell do i have here and can i replace the #4 exhaust screw or do i have to pull out the whole assembly.
Jake Raby |
Jun 22 2009, 02:24 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
It CAN get into the engine via the oil return slots for oil in the pushrod tubes..
the larger 10mm adjusters use a 14mm hex, not a 13. This is why these are TORQUED every time they are tightened.. They will come loose if given the opportunity. |
Lo-Fi Version | Time is now: 29th May 2024 - 04:02 AM |
