valve adjustmentment screw gone, i am a danger to myself and others |
nycchef |
Jun 22 2009, 11:41 AM
mechanical moron Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
while searching for the cause of the incessent popping in my carbs, i decided to check my valves. turns out the adjustment screw for the # 4 exhaust is MISSING. i don't know how i did this having adjusted the valves last year before installing the engine. also the nuts on the rest of the rocker assembly are not 13mm , they are larger and possibly american. what the hell do i have here and can i replace the #4 exhaust screw or do i have to pull out the whole assembly.
geniusanthony |
Jun 22 2009, 03:41 PM
Its a brand new "Chrome-sicle" Group: Members Posts: 517 Joined: 12-December 05 From: Alexandria,VA Member No.: 5,266 Region Association: MidAtlantic Region |
I just went and investigated my spare case which was a T4 bus unit, the slots for the oil drain in the lifter bore are 3/4" x 1/4" approx. The lifter is not in the way cause the oil has to get back to the sump somehow, Additionally I stuck a lifter in and sure enough there is room. Both your adjuster and my rocker not could fit through there and I am about to got diggin. Recall there are two circular covers in the sump, perhaps a magnet on a stick will fish em out... good luck with yours chef.
Lo-Fi Version | Time is now: 4th June 2024 - 01:12 PM |
