5 lug rims with stock -4 brakes?, how? |
tat2dphreak |
Jun 21 2009, 04:16 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
I've been looking at rims a lot lately, since I really don't like the westerns I have...
I've thought of 4 lug fuchs and revolutions(if I could find any)... but I really like the 5 lug phone dials... what would I have to do to use phone dials with my -4 brakes? redrill? spacers? adapters? what's needed. my brakes are new, eric-shea rebuilt (beautiful) brakes, so I would hate to swap them for 911 brakes... (IMG:style_emoticons/default/headbang.gif) |
RJMII |
Jun 21 2009, 08:23 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
The bolt on solution from Eric.
kit for early car, that uses stock brakes: http://www.pmbperformance.com/catalog/item...565/1355581.htm then when you're ready to change your front rotors, you'll need to get the redrilled front rotors: http://www.pmbperformance.com/catalog/item...565/1355570.htm As long as you don't warp the rotors, you should be good for a few years. =o) |
underthetire |
Jun 21 2009, 08:54 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
The bolt on solution from Eric. kit for early car, that uses stock brakes: http://www.pmbperformance.com/catalog/item...565/1355581.htm then when you're ready to change your front rotors, you'll need to get the redrilled front rotors: http://www.pmbperformance.com/catalog/item...565/1355570.htm As long as you don't warp the rotors, you should be good for a few years. =o) Still need spacers for the 16" phone dials. They are the late offset. |
jaxdream |
Jun 22 2009, 11:07 PM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
The bolt on solution from Eric. kit for early car, that uses stock brakes: http://www.pmbperformance.com/catalog/item...565/1355581.htm then when you're ready to change your front rotors, you'll need to get the redrilled front rotors: http://www.pmbperformance.com/catalog/item...565/1355570.htm As long as you don't warp the rotors, you should be good for a few years. =o) Still need spacers for the 16" phone dials. They are the late offset. Try the 21 mm spacers , I got a set that I mocked up , put on one of my 7 X 15 52mm offset Phonies , ( it has 215 / 60 / 15 tires on them , came with the wheels ) cleared my driver's side rear , disconnected the spring / strut , put on a spare strut with no spring , jacked it up as far as the strut allowed , still didn't rub , not a lot of room left , but did not rub when turned . This was on a arm that is being converted to 5 lug , so I put on rotor , spacer , wheel , no problems. No fender pulling , although a PO had ground / cut the lip down which wouldn't be real hard to do if needed. Check them out , they sometimes can be had cheap. Jaxdream |
Lo-Fi Version | Time is now: 4th June 2024 - 12:58 PM |
