> 914/6 axles questions
Project 6
post Jun 23 2009, 09:19 AM
large member
OK, so I'm ready to install the engine and found a surprise. The PO was going to install a later model trans. As such, they installed 915 style stub axles. The oem stubs are lost in space.
The existing stubs don't bolt up to the 914/4 axles and CVs I was going to use. The 2.0/6 "S" spec motor puts out about 140hp. So I wasn't worried about twisting them with high torque since I used this set up with a 3.0 in the past.
My questions is....are 914/6 AXLES which I might have access to, compatible with 915 sized CVs? FYI 914/6 CVs have been NLA for 20+ years....
Since I have the sub axles, can easily find drive flanges for the trans, I was thinking this would be an easy alternative. Does the 914/6 axle have the same spline count? 28 is what I've been told.
Simply using a 911 axle won't work, too long. Buying 914/6 stub axles is an expensive deal, $5-600. Mittelmotor and Otto....
Some good news, I HAVE been able to locate one stub axle...it will need a little machining as it's a bit corroded. But I'm looking for alternatives.
Anyone BTDT? Or even better....an orphan 914/6 stubbie?
Lavanaut
post Jun 23 2009, 01:13 PM
Hungry Mind : Thirsty Gullet
QUOTE(Project 6 @ Jun 23 2009, 12:00 PM) *
The best scenario is finding another /6 stub axle....after going thru Krusty's pile of discards. We found one just hanging about on a file cabinet with three other 914/4 stub axles.
QUOTE(SirAndy @ Jun 23 2009, 12:08 PM) *
QUOTE(Lavanaut @ Jun 23 2009, 10:50 AM) *
how you going to do 5-lug using /4 hubs?
With a tool called a "drill" ... (IMG:style_emoticons/default/shades.gif)
That's your answer to "are 914/6 AXLES which I might have access to, compatible with 915 sized CVs?"...? Switch to 4-lug and drill for 5? Hmm.
post Jun 23 2009, 01:27 PM
Resident German
QUOTE(Lavanaut @ Jun 23 2009, 11:13 AM) *
Yes. That's my answer. Do you have a better one???
914/6 stuff is mighty expensive. Good luck finding a 914/6 stub axle.
And if i read his post correctly, he has /4 CVs and /4 axle shafts that he's trying to mate to mixed/matched 911 parts.
So yes, my answer still is to go to a /4 setup and sell off the 911 and /6 parts he already has.
At least i'm trying to come up with a solution instead of just talking down people who are trying to help.
Lavanaut
post Jun 23 2009, 02:04 PM
QUOTE(SirAndy @ Jun 23 2009, 12:27 PM) *
Yes, try to find another 914-6 stub axle if possible, and if that doesn't pan out look into Sway-a-Way axles as an alternative to 914-6. That was in my first post in this thread, maybe you glossed over it. I feel it's a better approach because he can use the beefier parts and doesn't have to use a tool called a "drill" to fundamentally reduce the integrity of his parts.
And hey, sounds like he found a single 914-6 stub axle! If that's the case it's a non-issue in the end. (IMG:style_emoticons/default/cheer.gif)
post Jun 23 2009, 02:10 PM
Resident German
QUOTE(Lavanaut @ Jun 23 2009, 12:04 PM) *
You got any real world data to back up that claim? If so, i'd like to see it ...
(IMG:style_emoticons/default/shades.gif) Andy
Lavanaut
post Jun 23 2009, 02:35 PM
QUOTE(SirAndy @ Jun 23 2009, 01:10 PM) *
No. In my mind it's a matter of physics, but I digress.
QUOTE(SirAndy @ Jun 23 2009, 01:15 PM) *
Transmission | Output Flange | CV | Axle Shaft | CV | Stub Axle | Hub
CV Constant Velocity Joint
Ok I'll quit muddying this thread now.
Project 6   914/6 axles questions   Jun 23 2009, 09:19 AM
Dr Evil   Switch to regular /4 stubs and output flanges and ...   Jun 23 2009, 11:06 AM
SirAndy   Switch to regular /4 stubs and output flanges and...   Jun 23 2009, 12:42 PM
Lavanaut   Switch to regular /4 stubs and output flanges an...   Jun 23 2009, 12:50 PM
SirAndy   how you going to do 5-lug using /4 hubs? With a t...   Jun 23 2009, 01:08 PM
SLITS   Ok Mike, I have our axle supervisor looking to se...   Jun 23 2009, 11:12 AM
Lavanaut   I have our axle supervisor looking to see if any ...   Jun 23 2009, 12:34 PM
pcar916   914-6 axles are splined differently from the 4...   Jun 23 2009, 11:35 AM
Lavanaut   I think this issue gets confusing because differen...   Jun 23 2009, 12:41 PM
SirAndy   I think this issue gets confusing because differe...   Jun 23 2009, 02:15 PM
mikez   To use a 914/4 stub axle. You need a 914/4 hub. ...   Jun 23 2009, 12:46 PM
Project 6   What I have now. tranny <---> flange ...   Jun 23 2009, 01:00 PM
Lavanaut   The best scenario is finding another /6 stub axle...   Jun 23 2009, 01:13 PM
SirAndy   That's your answer to [i]"are 914/6 AXLE...   Jun 23 2009, 01:27 PM
Lavanaut   Yes. That's my answer. Do [b]you have a bette...   Jun 23 2009, 02:04 PM
SirAndy   and doesn't have to use a tool called a ...   Jun 23 2009, 02:10 PM
Lavanaut   You got any real world data to back up that claim...   Jun 23 2009, 02:35 PM
Project 6   "are 914/6 AXLES which I might have access to...   Jun 23 2009, 01:35 PM
markb   You're welcome to come up & dig thru our c...   Jun 23 2009, 01:39 PM
Dr Evil   Eric Shea sells drilled 5 lug hubs for like ...   Jun 23 2009, 01:42 PM
Project 6   Again, all I'm missing at this point is ONE /6...   Jun 23 2009, 01:47 PM
SirAndy   Again, all I'm missing at this point is ONE /...   Jun 23 2009, 01:56 PM
Cap'n Krusty   You all done squabbling? I believe mid-911 CVs wi...   Jun 23 2009, 02:38 PM
SLITS   Ok Mike .... you're leading a charmed life eve...   Jun 23 2009, 03:01 PM
Project 6   Sounds like some old phart just got a freebie on C...   Jun 23 2009, 03:31 PM
Richard Casto   An earlier post asked about spline counts. I have...   Jun 23 2009, 03:42 PM
charliew   I'm pretty sure I read here somewhere that 911...   Jun 23 2009, 04:07 PM
Project 6   Long or short...I agree, they don't fit.   Jun 23 2009, 04:14 PM
dr914@autoatlanta.com   six and four cv axles connect to the same input an...   Jun 23 2009, 04:20 PM
Project 6   Further research shows 69-77 stubbies are the same...   Jun 23 2009, 04:22 PM
SirAndy   Here's a set from eBay. Those don't look...   Jun 23 2009, 04:55 PM
Richard Casto   Here's a set from eBay. Those don't loo...   Jun 23 2009, 05:02 PM
Richard Casto   Further research shows 69-77 stubbies are the sam...   Jun 23 2009, 04:58 PM
Cap'n Krusty   Further research shows 69-77 stubbies are the sam...   Jun 23 2009, 06:11 PM
Lavanaut   Agreed with all above ~ those on eBay look wrong. ...   Jun 23 2009, 05:03 PM
Richard Casto   Agreed with all above ~ those on eBay look wrong....   Jun 23 2009, 05:14 PM
SLITS   Here's some information for you Mike (and anyb...   Jun 23 2009, 05:05 PM
Richard Casto   Now, what would a 914/6 CV axle assembly be? I ...   Jun 23 2009, 05:10 PM
mikez   Now, what would a 914/6 CV axle assembly be? I...   Jun 23 2009, 05:15 PM
Lavanaut   Here's some information for you Mike (and any...   Jun 23 2009, 05:14 PM
mikez   :stir: Stirring the pot O Krusty one....stirring i...   Jun 23 2009, 06:15 PM
SLITS   Hell John .... at my age '65 - '68 are cur...   Jun 23 2009, 06:18 PM
mikez   I know who's shorter....who's older?   Jun 23 2009, 06:20 PM
SLITS   I think I have him by a year or so.   Jun 23 2009, 06:25 PM
914Sixer   Why not do it the simple way as the Dr says.? Get ...   Jun 23 2009, 07:09 PM
Cap'n Krusty   Why not do it the simple way as the Dr says.? Get...   Jun 23 2009, 08:16 PM
mikez   $600 bucks......they should sleep with me and...   Jun 23 2009, 07:12 PM
914Sixer   I paid $350 for my stub axles from Otto's...   Jun 23 2009, 07:24 PM
Project 6   Cheap is gud....   Jun 24 2009, 02:42 PM
9146986   PM Sent   Jun 24 2009, 03:43 PM
Cupomeat   :stir: Just FYI, the 912 shafts were used on 69-79...   Jun 24 2009, 03:58 PM
Derek Seymour   :stir: Just FYI, the 912 shafts were used on 69-7...   Jun 24 2009, 06:44 PM
Cap'n Krusty   :stir: Just FYI, the 912 shafts were used on 69-7...   Jun 24 2009, 07:21 PM
r_towle   :stir: Just FYI, the 912 shafts were used on 69-...   Jun 24 2009, 07:39 PM
sharper   Here is my two cents since I went through this jus...   Jun 24 2009, 04:27 PM
Rob-O 1167   Jeez...talk about a hijacked thread. So did get y...   Jun 24 2009, 07:44 PM
SLITS   Jeez...talk about a hijacked thread. So did get ...   Jun 24 2009, 08:58 PM
Cap'n Krusty   Jeez...talk about a hijacked thread. So did get...   Jun 24 2009, 09:21 PM
SLITS   [quote name='SLITS' post='1185138' date='Jun 24 2...   Jun 24 2009, 10:13 PM
mikez   Krusty get his back, SLITs gets a pair of CDI boxe...   Jun 25 2009, 12:17 AM
Rob-O 1167   I am 100% sure they're from a /6. Length is 2...   Jun 26 2009, 09:11 AM
Lavanaut   deleted :ph34r:   Jun 26 2009, 10:15 AM
Project 6   Well the ones I got in the mail are the same size ...   Jul 1 2009, 09:44 AM
brp986s   Just dealt with this. Car is a '70 914-6 (#24...   Aug 30 2009, 10:07 PM
brp986s   Although the 911 and 914-6 axles are 25 spline, a ...   Aug 30 2009, 10:14 PM
brp986s   You can use a 100mm 911 stub in a 914-6 hub. Both...   Aug 30 2009, 10:19 PM
brp986s   To make it work, get 0.75 inch spacer. This one m...   Aug 30 2009, 10:24 PM
brp986s   wullah:   Aug 30 2009, 10:42 PM
mikez   First off, I wouldn't buy warm spit PMS. He d...   Aug 30 2009, 10:44 PM
brp986s   First off, I wouldn't buy warm spit PMS. He ...   Aug 30 2009, 11:02 PM
Eric_Shea   Buying the proper length axles is better IMO. ...   Aug 31 2009, 12:43 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:13 PM
