Project 6 |
large member ![]() ![]() Group: Members Posts: 359 Joined: 30-December 02 From: Utah Member No.: 51 Region Association: None ![]() ![]() |
OK, so I'm ready to install the engine and found a surprise. The PO was going to install a later model trans. As such, they installed 915 style stub axles. The oem stubs are lost in space.
The existing stubs don't bolt up to the 914/4 axles and CVs I was going to use. The 2.0/6 "S" spec motor puts out about 140hp. So I wasn't worried about twisting them with high torque since I used this set up with a 3.0 in the past. My questions is....are 914/6 AXLES which I might have access to, compatible with 915 sized CVs? FYI 914/6 CVs have been NLA for 20+ years.... Since I have the sub axles, can easily find drive flanges for the trans, I was thinking this would be an easy alternative. Does the 914/6 axle have the same spline count? 28 is what I've been told. Simply using a 911 axle won't work, too long. Buying 914/6 stub axles is an expensive deal, $5-600. Mittelmotor and Otto.... Some good news, I HAVE been able to locate one stub axle...it will need a little machining as it's a bit corroded. But I'm looking for alternatives. Anyone BTDT? Or even better....an orphan 914/6 stubbie? |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Ok Mike .... you're leading a charmed life ever since you dropped the Ass Avatar ... I have the stub axle you are looking for.
In fact, I might have a pair. Further, I might have a couple of pairs. Send gold .... paper money is worthless (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 17th June 2024 - 08:16 AM |
