| Project 6 |
Jun 23 2009, 09:19 AM
large member ![]() ![]() Group: Members Posts: 359 Joined: 30-December 02 From: Utah Member No.: 51 Region Association: None |
OK, so I'm ready to install the engine and found a surprise. The PO was going to install a later model trans. As such, they installed 915 style stub axles. The oem stubs are lost in space.
The existing stubs don't bolt up to the 914/4 axles and CVs I was going to use. The 2.0/6 "S" spec motor puts out about 140hp. So I wasn't worried about twisting them with high torque since I used this set up with a 3.0 in the past. My questions is....are 914/6 AXLES which I might have access to, compatible with 915 sized CVs? FYI 914/6 CVs have been NLA for 20+ years.... Since I have the sub axles, can easily find drive flanges for the trans, I was thinking this would be an easy alternative. Does the 914/6 axle have the same spline count? 28 is what I've been told. Simply using a 911 axle won't work, too long. Buying 914/6 stub axles is an expensive deal, $5-600. Mittelmotor and Otto.... Some good news, I HAVE been able to locate one stub axle...it will need a little machining as it's a bit corroded. But I'm looking for alternatives. Anyone BTDT? Or even better....an orphan 914/6 stubbie? |
| Project 6 |
Jun 24 2009, 02:42 PM
Cheap is gud....
Project 6 914/6 axles questions Jun 23 2009, 09:19 AM
Dr Evil Switch to regular /4 stubs and output flanges and ... Jun 23 2009, 11:06 AM
Switch to regular /4 stubs and output flanges and... Jun 23 2009, 12:42 PM
Lavanaut
Switch to regular /4 stubs and output flanges an... Jun 23 2009, 12:50 PM
how you going to do 5-lug using /4 hubs?
With a t... Jun 23 2009, 01:08 PM
SLITS Ok Mike,
I have our axle supervisor looking to se... Jun 23 2009, 11:12 AM
Lavanaut
I have our axle supervisor looking to see if any ... Jun 23 2009, 12:34 PM
pcar916 914-6 axles are splined differently from the 4... Jun 23 2009, 11:35 AM
Lavanaut I think this issue gets confusing because differen... Jun 23 2009, 12:41 PM
I think this issue gets confusing because differe... Jun 23 2009, 02:15 PM
mikez To use a 914/4 stub axle. You need a 914/4 hub. ... Jun 23 2009, 12:46 PM
Project 6 What I have now.
tranny <---> flange ... Jun 23 2009, 01:00 PM
Lavanaut
The best scenario is finding another /6 stub axle... Jun 23 2009, 01:13 PM
That's your answer to [i]"are 914/6 AXLE... Jun 23 2009, 01:27 PM
Lavanaut
Yes. That's my answer. Do [b]you have a bette... Jun 23 2009, 02:04 PM
and doesn't have to use a tool called a ... Jun 23 2009, 02:10 PM
Lavanaut
You got any real world data to back up that claim... Jun 23 2009, 02:35 PM
Project 6 "are 914/6 AXLES which I might have access to... Jun 23 2009, 01:35 PM
markb You're welcome to come up & dig thru our c... Jun 23 2009, 01:39 PM
Dr Evil Eric Shea sells drilled 5 lug hubs for like ... Jun 23 2009, 01:42 PM
Project 6 Again, all I'm missing at this point is ONE /6... Jun 23 2009, 01:47 PM
Again, all I'm missing at this point is ONE /... Jun 23 2009, 01:56 PM
Cap'n Krusty You all done squabbling? I believe mid-911 CVs wi... Jun 23 2009, 02:38 PM
SLITS Ok Mike .... you're leading a charmed life eve... Jun 23 2009, 03:01 PM
Project 6 Sounds like some old phart just got a freebie on C... Jun 23 2009, 03:31 PM
Richard Casto An earlier post asked about spline counts. I have... Jun 23 2009, 03:42 PM
charliew I'm pretty sure I read here somewhere that 911... Jun 23 2009, 04:07 PM
Project 6 Long or short...I agree, they don't fit. Jun 23 2009, 04:14 PM
dr914@autoatlanta.com six and four cv axles connect to the same input an... Jun 23 2009, 04:20 PM
Project 6 Further research shows 69-77 stubbies are the same... Jun 23 2009, 04:22 PM
Here's a set from eBay.
Those don't look... Jun 23 2009, 04:55 PM
Richard Casto
Those don't loo... Jun 23 2009, 05:02 PM
Richard Casto
Further research shows 69-77 stubbies are the sam... Jun 23 2009, 04:58 PM
Cap'n Krusty
Further research shows 69-77 stubbies are the sam... Jun 23 2009, 06:11 PM
Lavanaut Agreed with all above ~ those on eBay look wrong. ... Jun 23 2009, 05:03 PM
Richard Casto
Agreed with all above ~ those on eBay look wrong.... Jun 23 2009, 05:14 PM
SLITS Here's some information for you Mike (and anyb... Jun 23 2009, 05:05 PM
Richard Casto
Now, what would a 914/6 CV axle assembly be?
I ... Jun 23 2009, 05:10 PM
mikez
I... Jun 23 2009, 05:15 PM
Lavanaut
Here's some information for you Mike (and any... Jun 23 2009, 05:14 PM
mikez :stir: Stirring the pot O Krusty one....stirring i... Jun 23 2009, 06:15 PM
SLITS Hell John .... at my age '65 - '68 are cur... Jun 23 2009, 06:18 PM
mikez I know who's shorter....who's older? Jun 23 2009, 06:20 PM
SLITS I think I have him by a year or so. Jun 23 2009, 06:25 PM
914Sixer Why not do it the simple way as the Dr says.? Get ... Jun 23 2009, 07:09 PM
Cap'n Krusty
Why not do it the simple way as the Dr says.? Get... Jun 23 2009, 08:16 PM
mikez $600 bucks......they should sleep with me and... Jun 23 2009, 07:12 PM
914Sixer I paid $350 for my stub axles from Otto's... Jun 23 2009, 07:24 PM
9146986 PM Sent Jun 24 2009, 03:43 PM
Cupomeat :stir: Just FYI, the 912 shafts were used on 69-79... Jun 24 2009, 03:58 PM
Derek Seymour
:stir: Just FYI, the 912 shafts were used on 69-7... Jun 24 2009, 06:44 PM
Cap'n Krusty
:stir: Just FYI, the 912 shafts were used on 69-7... Jun 24 2009, 07:21 PM
r_towle
:stir: Just FYI, the 912 shafts were used on 69-... Jun 24 2009, 07:39 PM
sharper Here is my two cents since I went through this jus... Jun 24 2009, 04:27 PM
Rob-O 1167 Jeez...talk about a hijacked thread. So did get y... Jun 24 2009, 07:44 PM
SLITS
Jeez...talk about a hijacked thread. So did get ... Jun 24 2009, 08:58 PM
Cap'n Krusty
Jeez...talk about a hijacked thread. So did get... Jun 24 2009, 09:21 PM
SLITS
[quote name='SLITS' post='1185138' date='Jun 24 2... Jun 24 2009, 10:13 PM
mikez Krusty get his back, SLITs gets a pair of CDI boxe... Jun 25 2009, 12:17 AM
Rob-O 1167 I am 100% sure they're from a /6.
Length is 2... Jun 26 2009, 09:11 AM
Lavanaut deleted :ph34r: Jun 26 2009, 10:15 AM
Project 6 Well the ones I got in the mail are the same size ... Jul 1 2009, 09:44 AM
brp986s Just dealt with this. Car is a '70 914-6 (#24... Aug 30 2009, 10:07 PM
brp986s Although the 911 and 914-6 axles are 25 spline, a ... Aug 30 2009, 10:14 PM
brp986s You can use a 100mm 911 stub in a 914-6 hub. Both... Aug 30 2009, 10:19 PM
brp986s To make it work, get 0.75 inch spacer. This one m... Aug 30 2009, 10:24 PM
brp986s wullah:
Aug 30 2009, 10:42 PM
mikez First off, I wouldn't buy warm spit PMS. He d... Aug 30 2009, 10:44 PM
brp986s
First off, I wouldn't buy warm spit PMS. He ... Aug 30 2009, 11:02 PM
Eric_Shea Buying the proper length axles is better IMO. ... Aug 31 2009, 12:43 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:12 PM |
