> Need transmission problem diagnosis..., Or best guess
Porsche Rescue
post Jun 28 2009, 02:45 PM
Saving and Enjoying Old Porsches
Started my '70 tail shifter this morning, attempted to engage reverse and heardf/felt a horrible grind (kind of like the clutch pedal was not depressed, but it was). Quickly returned to neutral and tried again. I engaged reverse OK and backed out of the garage. But I heard a grinding/growling noise while moving and felt the sensation of something restricting movement (like brake on, but it wasnt'). Moved it back and forth in the driveway in all gears. It makes the same noise in all 5 forward gears as soon as I release the clutch. Reverse now seems almost OK.
Where do I start? Could it be a linkage issue (the front two bushings were new a few months ago)? It shifts smoothly when clutch pedal is depressed. Is something broken in the tranny? All opinions welcome.
Dr Evil
post Jun 28 2009, 03:40 PM
Send me your transmission!
Sounds like you have a clutch tube or other clutch related problem. Reverse grinding is a good indicator that the clutch is not fully disengaging. R does not have a synchro band and tooth set up like the other gears and so needs the clutch to be fully engaged to relieve force on the moving components. The other gears grinding support this diagnosis, but alone would not only do so.
I would check the following:
1-Clutch pedal disengagement; it should disengage in the 1st 1/3 of travel
2-Adjustment nuts at the end of the clutch cable. They can move if not double nutted. Can lead to #1 changing
3-See if you can wiggle your clutch for. If there is a lot of play in the clutch fork then your bushing in the fork is gone and your clutch behavior is going to be sucky.
These are quick checks that will give us some good data to start with. (IMG:style_emoticons/default/smile.gif)
Porsche Rescue   Need transmission problem diagnosis...   Jun 28 2009, 02:45 PM
Cap'n Krusty   Jack it up, put it on stands, loosen the fill plug...   Jun 28 2009, 03:22 PM
Dr Evil   Sounds like you have a clutch tube or other clutch...   Jun 28 2009, 03:40 PM
Cap'n Krusty   Sounds like you have a clutch tube or other clutc...   Jun 28 2009, 04:56 PM
Dr Evil   Sounds like you have a clutch tube or other clut...   Jun 28 2009, 06:01 PM
Cap'n Krusty   [quote name='Cap'n Krusty' post='1186428' dat...   Jun 28 2009, 08:54 PM
J P Stein   Sorry, Doc, I'm callin' it like I see it...   Jun 28 2009, 09:13 PM
Dr Evil   Sorry, Doc, I'm callin' it like I see i...   Jun 28 2009, 09:54 PM
Cap'n Krusty   [quote name='J P Stein' post='1186504' date='Jun ...   Jun 28 2009, 10:24 PM
Porsche Rescue   I first tightened the clutch adjustment nut as I h...   Jun 28 2009, 05:21 PM
Jacob   As soon as I begin to engage the clutch I hear t...   Jun 28 2009, 05:39 PM
Cap'n Krusty   As soon as I begin to engage the clutch I hear ...   Jun 28 2009, 08:04 PM
Porsche Rescue   Not sure of clutch age. Major engine work about 5K...   Jun 28 2009, 05:52 PM
Dr Evil   Not sure of clutch age. Major engine work about 5...   Jun 28 2009, 06:05 PM
Porsche Rescue   Thanks Dr. I have a second confirming opinion from...   Jun 28 2009, 06:08 PM
J P Stein   I have a good (2 actually but one is NFS) intermed...   Jun 28 2009, 06:51 PM
Porsche Rescue   Ok, but can someone tell me if the "guts...   Jun 28 2009, 09:51 PM
Cap'n Krusty   Ok, but can someone tell me if the "guts...   Jun 28 2009, 10:07 PM
Porsche Rescue   Thank you Cap'n. Sounds like I need to repair ...   Jun 28 2009, 10:16 PM
Dr Evil   Thank you Cap'n. Sounds like I need to repair...   Jun 28 2009, 10:32 PM
RobW   C'mon you guys :hugme:   Jun 28 2009, 10:29 PM
Porsche Rescue   OK, now what? While in the process of removing the...   Jul 2 2009, 09:53 AM
Dr Evil   How it acts under hand torque is completely differ...   Jul 2 2009, 10:42 AM
J P Stein   Tore appart Jim's trans this afternoon. The gu...   Jul 9 2009, 09:02 PM
Dr Evil   That is the problem with doing diagnosis over the ...   Jul 9 2009, 09:21 PM
J P Stein   Everything I can see looks very nice & turns s...   Jul 9 2009, 09:51 PM
Jax914   pilot bearing in the flywheel?   Jul 10 2009, 12:52 PM
Porsche Rescue   Pilot bearing feels good to the pinky finger, look...   Jul 10 2009, 01:08 PM
kwales   You sure it's not the throwout bearing??? I...   Jul 10 2009, 04:13 PM
Porsche Rescue   TO bearing is smooth and quiet in my hand and in t...   Jul 10 2009, 06:12 PM
Dr Evil   Has your flywheel been resurfaced before? If the s...   Jul 11 2009, 10:52 AM
kwales   Ok, let's think this through. Tranny is out o...   Jul 11 2009, 11:51 AM
Porsche Rescue   Growling noise only when tranny in gear (any gear)...   Jul 11 2009, 12:03 PM
kwales   Well, does it growl when the clutch pedal is in an...   Jul 11 2009, 10:24 PM
Porsche Rescue   No noise when in gear with the clutch "in...   Jul 12 2009, 09:27 AM
kwales   I'm gonna put on my Patent Law and my engineer...   Jul 12 2009, 10:58 AM
Porsche Rescue   Noise begins with first clutch contact with flywhe...   Jul 12 2009, 11:05 AM
Porsche Rescue   Here are some pics. One theory is that the center ...   Jul 12 2009, 11:08 AM
kwales   Looks glazed to me. The clutch disk is a two piece...   Jul 12 2009, 11:22 AM
Bleyseng   use the 6 spring clutch disc for a early 911, yes ...   Jul 12 2009, 12:19 PM
- Lo-Fi Version Time is now: 1st August 2025 - 04:04 AM
