| rick 918-S |
Mar 15 2009, 04:37 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,239 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
OK, I'm thinking about adding a passenger side factory style mirror. The factory installed a threaded plate in the drivers door for the mirror fasteners but the passenger door was optional. Does anyone know if the mount plate is in the door but just not drilled through the outer skin?
My car is a 1972... (IMG:style_emoticons/default/idea.gif) I think it still has the original right door. EDIT: I ended up using the punch from the bottom method but I like the pointed bolt from the bottom idea. |
| ahdoman |
Jun 28 2009, 04:19 PM
It's phonetic...Ah-D-O-Man (Audioman) ![]() ![]() ![]() Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
When I did this I used a bolt that was the same thread as the mirror screw (only longer). Sharpened the end to a dull point and then threaded it in from the back. The dimple was perfectly centered that way. I also used a drill that was a size or two larger than the hole so that I wouldn't cut into the threads. It acted a little like a counter sink.
rick 918-S Here is some great tips for mounting the right side mirror Mar 15 2009, 04:37 PM
southernmost914 The mounting plate is there, you just need to dril... Mar 15 2009, 04:44 PM
r_towle Its there.
You need to drill from the outside.
I ... Mar 15 2009, 04:50 PM
Phoenix-MN I took a small spring loaded center punch and used... Mar 15 2009, 05:28 PM
rick 918-S Cool, I thought it was there, just wasn't posi... Mar 15 2009, 08:29 PM
PRS914-6 I drilled mine from the inside out. However the d... Mar 15 2009, 08:57 PM
gothspeed That is why ..... I love this forum :) ...... I ju... Jun 28 2009, 02:07 PM
RobW +1 on the advice given. You want to punch a hole w... Jun 28 2009, 03:57 PM
warrenoliver
When I did this I used a bolt that was the same t... Jun 29 2009, 07:17 AM
Cap'n Krusty No one here has mentioned that the plate for the r... Jun 28 2009, 04:51 PM
gothspeed
No one here has mentioned that the plate for the ... Jun 29 2009, 02:37 AM
r_towle
No one here has mentioned that the plate for the... Jun 29 2009, 08:25 PM
Project 6 Roll the window up, pull the door panel, use your ... Jun 29 2009, 09:02 AM
gothspeed
Roll the window up, pull the door panel, use your... Jun 29 2009, 08:17 PM
iamchappy After i dimpled the spot from inside the door i th... Jun 29 2009, 08:24 PM
GeorgeRud Just punch it from the inside, why take a chance? ... Jun 29 2009, 10:53 PM
r_towle Door striker plate screw.
Rich Jun 29 2009, 11:20 PM
Van914 Last night I installed the right side mirror I bou... Jul 10 2009, 05:17 AM
gothspeed My 914 is a 1973 ...... I did the spring loaded pu... Aug 7 2009, 04:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd April 2026 - 02:07 AM |
