Porsche Rescue |
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None ![]() |
Started my '70 tail shifter this morning, attempted to engage reverse and heardf/felt a horrible grind (kind of like the clutch pedal was not depressed, but it was). Quickly returned to neutral and tried again. I engaged reverse OK and backed out of the garage. But I heard a grinding/growling noise while moving and felt the sensation of something restricting movement (like brake on, but it wasnt'). Moved it back and forth in the driveway in all gears. It makes the same noise in all 5 forward gears as soon as I release the clutch. Reverse now seems almost OK.
Where do I start? Could it be a linkage issue (the front two bushings were new a few months ago)? It shifts smoothly when clutch pedal is depressed. Is something broken in the tranny? All opinions welcome. |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Sounds like you have a clutch tube or other clutch related problem. Reverse grinding is a good indicator that the clutch is not fully disengaging. R does not have a synchro band and tooth set up like the other gears and so needs the clutch to be fully engaged to relieve force on the moving components. The other gears grinding support this diagnosis, but alone would not only do so.
I would check the following: 1-Clutch pedal disengagement; it should disengage in the 1st 1/3 of travel 2-Adjustment nuts at the end of the clutch cable. They can move if not double nutted. Can lead to #1 changing 3-See if you can wiggle your clutch for. If there is a lot of play in the clutch fork then your bushing in the fork is gone and your clutch behavior is going to be sucky. These are quick checks that will give us some good data to start with. (IMG:style_emoticons/default/smile.gif) |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Sounds like you have a clutch tube or other clutch related problem. Reverse grinding is a good indicator that the clutch is not fully disengaging. R does not have a synchro band and tooth set up like the other gears and so needs the clutch to be fully engaged to relieve force on the moving components. The other gears grinding support this diagnosis, but alone would not only do so. I would check the following: 1-Clutch pedal disengagement; it should disengage in the 1st 1/3 of travel 2-Adjustment nuts at the end of the clutch cable. They can move if not double nutted. Can lead to #1 changing 3-See if you can wiggle your clutch for. If there is a lot of play in the clutch fork then your bushing in the fork is gone and your clutch behavior is going to be sucky. These are quick checks that will give us some good data to start with. (IMG:style_emoticons/default/smile.gif) Uhhhhh, Doc? I hope you check the symptoms on your human patients better than you did here. You missed "I engaged reverse OK and backed out of the garage. But I heard a grinding/growling noise while moving and felt the sensation of something restricting movement (like brake on, but it wasn't." The Cap'n |
Dr Evil |
Sounds like you have a clutch tube or other clutch related problem. Reverse grinding is a good indicator that the clutch is not fully disengaging. R does not have a synchro band and tooth set up like the other gears and so needs the clutch to be fully engaged to relieve force on the moving components. The other gears grinding support this diagnosis, but alone would not only do so. I would check the following: 1-Clutch pedal disengagement; it should disengage in the 1st 1/3 of travel 2-Adjustment nuts at the end of the clutch cable. They can move if not double nutted. Can lead to #1 changing 3-See if you can wiggle your clutch for. If there is a lot of play in the clutch fork then your bushing in the fork is gone and your clutch behavior is going to be sucky. These are quick checks that will give us some good data to start with. (IMG:style_emoticons/default/smile.gif) Uhhhhh, Doc? I hope you check the symptoms on your human patients better than you did here. You missed "I engaged reverse OK and backed out of the garage. But I heard a grinding/growling noise while moving and felt the sensation of something restricting movement (like brake on, but it wasn't." The Cap'n Umm, hey Captain Crunch, "attempted to engage reverse and heardf/felt a horrible grind" Tis what I was addressing. |
Cap'n Krusty |
Sounds like you have a clutch tube or other clutch related problem. Reverse grinding is a good indicator that the clutch is not fully disengaging. R does not have a synchro band and tooth set up like the other gears and so needs the clutch to be fully engaged to relieve force on the moving components. The other gears grinding support this diagnosis, but alone would not only do so. I would check the following: 1-Clutch pedal disengagement; it should disengage in the 1st 1/3 of travel 2-Adjustment nuts at the end of the clutch cable. They can move if not double nutted. Can lead to #1 changing 3-See if you can wiggle your clutch for. If there is a lot of play in the clutch fork then your bushing in the fork is gone and your clutch behavior is going to be sucky. These are quick checks that will give us some good data to start with. (IMG:style_emoticons/default/smile.gif) Uhhhhh, Doc? I hope you check the symptoms on your human patients better than you did here. You missed "I engaged reverse OK and backed out of the garage. But I heard a grinding/growling noise while moving and felt the sensation of something restricting movement (like brake on, but it wasn't." The Cap'n Umm, hey Captain Crunch, "attempted to engage reverse and heardf/felt a horrible grind" Tis what I was addressing. That's like treating a guy for a dizzy feeling and failing to notice his arm's been severed and he has no blood left............... Sorry, Doc, I'm callin' it like I see it. The Cap'n |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
Sorry, Doc, I'm callin' it like I see it. The Cap'n That's part of your charm. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 1st August 2025 - 04:14 AM |
