> Here is some great tips for mounting the right side mirror, TITLE CHANGED
rick 918-S
post Mar 15 2009, 04:37 PM
Hey nice rack! -Celette
OK, I'm thinking about adding a passenger side factory style mirror. The factory installed a threaded plate in the drivers door for the mirror fasteners but the passenger door was optional. Does anyone know if the mount plate is in the door but just not drilled through the outer skin?
My car is a 1972... (IMG:style_emoticons/default/idea.gif) I think it still has the original right door.
EDIT: I ended up using the punch from the bottom method but I like the pointed bolt from the bottom idea.
Cap'n Krusty
post Jun 28 2009, 04:51 PM
Cap'n Krusty
No one here has mentioned that the plate for the right side mirror is A LOT farther back on the door than it is on the left side. Just so you know ..............
The Cap'n
gothspeed
post Jun 29 2009, 02:37 AM
QUOTE(Cap'n Krusty @ Jun 28 2009, 03:51 PM) *
The Cap'n
(IMG:style_emoticons/default/unsure.gif) ................. I was under the impression it was identical distance ..... or 'mirror opposite' ...... (IMG:style_emoticons/default/confused24.gif)
Someone please post pics or clear this up before I swiss cheese my door .... (IMG:style_emoticons/default/sad.gif)
rick 918-S   Here is some great tips for mounting the right side mirror   Mar 15 2009, 04:37 PM
southernmost914   The mounting plate is there, you just need to dril...   Mar 15 2009, 04:44 PM
r_towle   Its there. You need to drill from the outside. I ...   Mar 15 2009, 04:50 PM
Phoenix-MN   I took a small spring loaded center punch and used...   Mar 15 2009, 05:28 PM
rick 918-S   Cool, I thought it was there, just wasn't posi...   Mar 15 2009, 08:29 PM
PRS914-6   I drilled mine from the inside out. However the d...   Mar 15 2009, 08:57 PM
gothspeed   That is why ..... I love this forum :) ...... I ju...   Jun 28 2009, 02:07 PM
RobW   +1 on the advice given. You want to punch a hole w...   Jun 28 2009, 03:57 PM
ahdoman   When I did this I used a bolt that was the same th...   Jun 28 2009, 04:19 PM
warrenoliver   When I did this I used a bolt that was the same t...   Jun 29 2009, 07:17 AM
Cap'n Krusty   No one here has mentioned that the plate for the r...   Jun 28 2009, 04:51 PM
gothspeed   No one here has mentioned that the plate for the ...   Jun 29 2009, 02:37 AM
r_towle   No one here has mentioned that the plate for the...   Jun 29 2009, 08:25 PM
Project 6   Roll the window up, pull the door panel, use your ...   Jun 29 2009, 09:02 AM
gothspeed   Roll the window up, pull the door panel, use your...   Jun 29 2009, 08:17 PM
iamchappy   After i dimpled the spot from inside the door i th...   Jun 29 2009, 08:24 PM
GeorgeRud   Just punch it from the inside, why take a chance? ...   Jun 29 2009, 10:53 PM
r_towle   Door striker plate screw. Rich   Jun 29 2009, 11:20 PM
Van914   Last night I installed the right side mirror I bou...   Jul 10 2009, 05:17 AM
gothspeed   My 914 is a 1973 ...... I did the spring loaded pu...   Aug 7 2009, 04:18 PM
- Lo-Fi Version Time is now: 3rd April 2026 - 01:58 AM
