> No turn signals!
silverteener
post Jun 28 2009, 02:13 PM
I've been having this issue with my turn signals. Sometimes they would work and sometimes they didn't (IMG:style_emoticons/default/confused24.gif) I thought maybe it was the switch so I swapped it out with another one I have but it didn't help. Actually they don't work at all now. I cleaned the metal on the steering wheel that contacts the turn signal switch. I checked my fuses and they are all good. I did notice that if I had the turn signal on with the key on the side marker light will stay on. Any suggestions on what to do next. I'm at a loss!
thanks
Scott
904svo
post Jun 29 2009, 09:05 PM
904SVO
Pull up the EM brake handle with the key on the Brake lamp in the gauge should work, if not remove the gas gauge and ground the black/white wire on the brake light bulb socket, if this works (lamp flashes) the black/white wire to the emergency switch (49A) is not connected or open. The black/green wire which is also connected to 49A, which runs to the turn signal switch thru the connector on the sterring column may not be making connection. ( First thing to check).
Try this and let me know.
- Lo-Fi Version Time is now: 26th May 2026 - 05:40 AM
