Windshield washer pump |
415PB |
Feb 6 2004, 08:17 PM
Member Group: Benefactors Posts: 498 Joined: 7-August 03 From: So Cal Member No.: 996 |
I have a hose connected to my spare tire for the windshield washer fluid container. Does air from the spare tire pressurize the container in order to clean the windshield? And would I have an electric pump for the container. My windshield washer system is not working and I wanted to get started on that problem next. Thanks for the help.
SirAndy |
Feb 7 2004, 12:07 AM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(415PB @ Feb 6 2004, 08:01 PM) Thanks, I will pick up an electric pump. did the conversion myself. unless you want to put big $$$ for a 914/6 washer bottle on the table, here's a tip on how to do it the cheap-o-way .... (IMG:style_emoticons/default/wink.gif) - get the aftermarket (914-6) electric pump. - detach the hose from the black bottle-cap on your stock /4 washer bottle. - drill a little hole in the cap. (about 1.5 mm). - connect the lower hose to the suction part of the pump. - connect the other side to the hose that goes to the jets. voila! you need to drill the little hole cause the normal hose attachment on the cap has a valve in it that doesn't allow air to flow in freely and therefore the pump wouldn't work well as it would struggle to get the water out of the bottle. Andy PS. if you have the wiper intermittent relay, you can hook up the pump to run with the wiper interval. i however just added a push button in the center console to run the pump separate from running the wipers. |
Lo-Fi Version | Time is now: 6th June 2024 - 07:06 PM |
