| jsaum |
Jul 4 2009, 07:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
After 5 years of procrastination and 5 more of contemplation I finally started working on my 1972. I just finished the hell hole repair and am now working towards putting the engine back in. I have a 75 parts car and am thinking about installing the side sift trans in the 72 my question is it a straight swap or do I need other after market parts to make it work? Do I use the engine tin and heater stuff from the 75? Thanks for the advice!
Jsaum Attached image(s)
| hcdmueller |
Jul 4 2009, 07:51 PM
????????????? ![]() ![]() ![]() Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England
You need the later engine mount bar and associated components, later shifter, and the shift rods that run from the shifter to the side of the trans. I think there are more things but I am not in front of my car right now so I could be wrong. There shouldn't be any changes to your heater or engine tin.
| jsaum |
Jul 4 2009, 08:31 PM
You need the later engine mount bar and associated components, later shifter, and the shift rods that run from the shifter to the side of the trans. I think there are more things but I am not in front of my car right now so I could be wrong. There shouldn't be any changes to your heater or engine tin. Great sounds like all of the stuff I need is on the parts car. |
| BMXerror |
Jul 4 2009, 08:39 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
You need the later engine mount bar and associated components, later shifter, and the shift rods that run from the shifter to the side of the trans. I think there are more things but I am not in front of my car right now so I could be wrong. There shouldn't be any changes to your heater or engine tin. Great sounds like all of the stuff I need is on the parts car. The only aftermarket piece you need is the firewall bushing that adapts from the early to late style. http://www.pelicanparts.com/cgi-bin/smart/...32%29%2C%20Each I don't know about you, but when I did the conversion I just replaced all the bushings at once because they tend to wear out and get sticky with time. Other than that, you need the later engine mount bar, rubber mounts, shifter, and full shift linkage. All stock, late model pieces. Good luck. Mark D. |
| jsaum |
Jul 5 2009, 01:43 AM
You need the later engine mount bar and associated components, later shifter, and the shift rods that run from the shifter to the side of the trans. I think there are more things but I am not in front of my car right now so I could be wrong. There shouldn't be any changes to your heater or engine tin. Great sounds like all of the stuff I need is on the parts car. The only aftermarket piece you need is the firewall bushing that adapts from the early to late style. http://www.pelicanparts.com/cgi-bin/smart/...32%29%2C%20Each I don't know about you, but when I did the conversion I just replaced all the bushings at once because they tend to wear out and get sticky with time. Other than that, you need the later engine mount bar, rubber mounts, shifter, and full shift linkage. All stock, late model pieces. Good luck. Mark D. Mark, Thanks for the link, I'll get the bushing on order. jsaum |
jsaum Side shift transmision install Jul 4 2009, 07:40 PM
Porsche Rescue You will need to use all the shift linkage (every ... Jul 4 2009, 08:36 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th November 2026 - 12:02 PM |
