jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
yesterday i wasn't sure if my fuel pump was getting power - or if my injestors were getting fuel - so i removed my injectors and my spark plugs - put my injectors into yogurt cups and turn the engine but no fuel.
i pulled my stock front mounted fuel pump and it did not make any noises when i turned the key. so i hooked up a volt meter to the fuel pump power wire - i was getting power - so i assumed my pump was bad. this morning i go out to the car and turn the key and the pump runs - so i turn over the engine some to see how fuel is going thru my injectors into the cups - they all spurt fuel - so i put the injectors back in and the plgs back in - and then - bam - the fuel pump is not getting power again?? i swapped out several reays - no success? http://www.youtube.com/watch?v=PrLcva9o8LA http://www.youtube.com/watch?v=8pipbKl_ZQU http://www.youtube.com/watch?v=bOAhJ9OZpm4 http://www.youtube.com/watch?v=9gMp0eoXvYc Attached thumbnail(s) ![]() |
anderssj |
Dog is my copilot... ![]() ![]() ![]() Group: Members Posts: 1,750 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region ![]() ![]() |
Jim,
I had a similar problem some time back--turned out to be an "old" fuse on the relay board. The fuse's ends had gotten kind of crappy, and it only made an intermittent connection. Just a thought . . . . Best, |
Lo-Fi Version | Time is now: 12th July 2025 - 02:57 PM |
