| silverteener |
Jun 28 2009, 02:13 PM
Member ![]() ![]() Group: Members Posts: 214 Joined: 9-August 05 From: East Moline, IL Member No.: 4,566 |
I've been having this issue with my turn signals. Sometimes they would work and sometimes they didn't (IMG:style_emoticons/default/confused24.gif) I thought maybe it was the switch so I swapped it out with another one I have but it didn't help. Actually they don't work at all now. I cleaned the metal on the steering wheel that contacts the turn signal switch. I checked my fuses and they are all good. I did notice that if I had the turn signal on with the key on the side marker light will stay on. Any suggestions on what to do next. I'm at a loss! thanks Scott |
| silverteener |
Jul 5 2009, 02:38 PM
I'm still trying to get this figured out. I found this yellow and red wire that came out of the plug that connects to the turn signal switch under the dash. Could this be my problem (IMG:style_emoticons/default/confused24.gif) all the other wires were firmly connected.
thanks Scott |
silverteener No turn signals! Jun 28 2009, 02:13 PM
inschool Have you checked for power at the turn signal/flas... Jun 28 2009, 04:19 PM
ericread How about providing the year of the car. Differen... Jun 29 2009, 01:22 PM
jt914-6 Does the emergency flasher work? On some 914's... Jun 29 2009, 05:22 PM
silverteener Did I mention I hate electrical problems! It... Jun 29 2009, 07:29 PM
silverteener I ran a jumper to #49 that the relay plugs into. ... Jun 29 2009, 08:39 PM
904svo Pull up the EM brake handle with the key on the Br... Jun 29 2009, 09:05 PM
buhs914 you could check the bulbs.. if they have different... Jun 29 2009, 09:26 PM
silverteener 904svo
I did what you said and grounded the blac... Jul 2 2009, 10:11 PM
904svo
904svo
I did what you said and grounded the bla... Jul 2 2009, 10:25 PM
silverteener this is probably a stupid question but i'm not... Jul 2 2009, 10:32 PM
904svo
this is probably a stupid question but i'm no... Jul 3 2009, 08:42 AM
904svo
I'm still trying to get this figured out. I ... Jul 5 2009, 02:59 PM
silverteener yeah,
It didn't work. I fixed the wire and d... Jul 5 2009, 05:31 PM
904svo sounds like you need a turn/signal switch. Jul 5 2009, 06:13 PM
silverteener so... do you have one :D
I'll look around ... Jul 5 2009, 08:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 26th May 2026 - 05:40 AM |
