> Is it possible to remove the torsion bars?, With the suspension on the car
turnaround89
post Jul 5 2009, 02:52 PM
This may be a really dumb question, but the front end of my car really need to be lowered and the adjusters are rusted stuck. Ive tried everything, penetrating oil for days on end, locking pliers, bolt out on a ratchet. the allen is rounded out as well which makes matters worse. I saw a picture of the torsion bar and adjuster out of an a arm, is it possible to pull the torsion bar and adjuster or should i just pull the whole a arm off to work on the adjuster part?
If i pull the a arm, i take it that means i need a front end alignment done, right?
Heres the picture i saw, that made me wonder if the adjuster and torsion bar can come out with the a arm still attached to the car
jmmotorsports = i hope you don't mind me using your picture for some help
(IMG:http://www.914world.com/bbs2/uploads/post-6658-1246635808.jpg)
turnaround89
post Jul 5 2009, 03:28 PM
So i need the adjuster bolt out to remove the adjuster and torsion bar. How difficult is it to remove the torsion bar and adjuster cap?
The front end is already up on jackstands, no rotors on the spindle, everything else is just hanging down, i take it the front end is unloaded as the car sits on the jackstands right now. With the front end unloaded, will i have to worry about the torsion bars being under any load at all?
Alright, not to worried about the alignment then, just want to get the adjuster cap off the car
- Lo-Fi Version Time is now: 5th July 2025 - 09:25 PM
