JOE M |
Member ![]() ![]() Group: Members Posts: 293 Joined: 27-August 07 From: N.H Member No.: 8,042 Region Association: None ![]() |
Rich,
I tried to add a pic in a p.m I sent you but could not do it. Can anyone tell me if looking at this pic there is an indication if the valves are burned or bad?The car has low compression and is near impossible to tune.The pic is of cylinders 1 and 2. Thanks. ![]() |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,120 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
The problem with the motorcycle jack comes when you try to get the engine out from under the car after lowering it. You either need your jacks and jackstand to go higher or you have to remove the motor from the motorcycle jack and slide it on the floor. Remove your rear valance to give yourself more clearance.
I have seen McMark do this in about 30 minutes. I can do it in an hour or so but I am not trying to make a living at it. Just keep guys like McMark from making a living off of me (IMG:style_emoticons/default/blink.gif) |
Lo-Fi Version | Time is now: 1st August 2025 - 06:12 AM |
