> are these valves bad?, picture attached.
JOE M
post Jul 5 2009, 10:31 AM
Rich,
I tried to add a pic in a p.m I sent you but could not do it. Can anyone tell me if looking at this pic there is an indication if the valves are burned or bad?The car has low compression and is near impossible to tune.The pic is of cylinders 1 and 2. Thanks.
ConeDodger
post Jul 5 2009, 03:34 PM
Apex killer!
The problem with the motorcycle jack comes when you try to get the engine out from under the car after lowering it. You either need your jacks and jackstand to go higher or you have to remove the motor from the motorcycle jack and slide it on the floor. Remove your rear valance to give yourself more clearance.
I have seen McMark do this in about 30 minutes. I can do it in an hour or so but I am not trying to make a living at it. Just keep guys like McMark from making a living off of me (IMG:style_emoticons/default/blink.gif)
JOE M
post Jul 5 2009, 03:45 PM
QUOTE(ConeDodger @ Jul 5 2009, 02:34 PM) *
I get it it now. After the engine is droped I slide it out with the dolly. You know what Rich told me this a while back. I will try to get a something better than a motorcycle jack.
JOE M   are these valves bad?   Jul 5 2009, 10:31 AM
Cap'n Krusty   Unless there's a wedge shaped hole where the v...   Jul 5 2009, 11:05 AM
JOE M   Unless there's a wedge shaped hole where the ...   Jul 5 2009, 11:21 AM
9146986   Pull the engine, you'll spend less time doing ...   Jul 5 2009, 11:26 AM
JOE M   Pull the engine, you'll spend less time doing...   Jul 5 2009, 11:30 AM
ericread   Pull the engine, you'll spend less time doin...   Jul 5 2009, 12:02 PM
McMark   How To Drop Your Engine Do it. You'll be sur...   Jul 5 2009, 12:09 PM
ConeDodger   Judging by your pictures, you have already put mor...   Jul 5 2009, 12:13 PM
JOE M   Judging by your pictures, you have already put mo...   Jul 5 2009, 12:43 PM
blitZ   I dont know how long it takes to drop the engine ...   Jul 5 2009, 01:04 PM
r_towle   Judging by your pictures, you have already put m...   Jul 5 2009, 02:35 PM
JOE M   [quote name='JOE M' post='1188598' date='Jul 5 20...   Jul 5 2009, 03:29 PM
SirAndy   I dont know how long it takes to drop the engine ...   Jul 5 2009, 03:16 PM
ConeDodger   The problem with the motorcycle jack comes when yo...   Jul 5 2009, 03:34 PM
JOE M   The problem with the motorcycle jack comes when y...   Jul 5 2009, 03:45 PM
dangrouche   I highly suggest CHris Foley's engine plate, c...   Jul 5 2009, 04:33 PM
r_towle   Tell me what you need. I have a few dollies...dont...   Jul 5 2009, 05:42 PM
r_towle   While you are on it... Get the shifter rod off. Re...   Jul 5 2009, 05:44 PM
JOE M   While you are on it... Get the shifter rod off. R...   Jul 5 2009, 06:35 PM
dakotaewing   While you are on it... Get the shifter rod off. ...   Jul 5 2009, 06:43 PM
JOE M   Thats what led me to trying to remove the heads wi...   Jul 5 2009, 07:04 PM
JOE M   Rich O.K I got all the cables and the shift linkag...   Jul 6 2009, 04:20 PM
r_towle   I could do this tomorrow if you want....its suppos...   Jul 6 2009, 05:07 PM
JOE M   Thanks sounds good. I could do this tomorrow if ...   Jul 6 2009, 06:18 PM
- Lo-Fi Version Time is now: 1st August 2025 - 06:08 AM
