JOE M |
Member ![]() ![]() Group: Members Posts: 293 Joined: 27-August 07 From: N.H Member No.: 8,042 Region Association: None ![]() |
Rich,
I tried to add a pic in a p.m I sent you but could not do it. Can anyone tell me if looking at this pic there is an indication if the valves are burned or bad?The car has low compression and is near impossible to tune.The pic is of cylinders 1 and 2. Thanks. ![]() |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
While you are on it...
Get the shifter rod off. Remove the clutch cable and the speedo cable...bend gently towards the front of the car and under the car...no kinking. Pull the throttle cable down below and put it with the clutch cable. From there...30 minutes and two beers...we are done. Rich |
JOE M |
While you are on it... Get the shifter rod off. Remove the clutch cable and the speedo cable...bend gently towards the front of the car and under the car...no kinking. Pull the throttle cable down below and put it with the clutch cable. From there...30 minutes and two beers...we are done. Rich OK Rich I will get the cables out and the shift rod. What kind of beer do you like?Im on this kick where i have been drinking misro brews.But I like any beer. So tomorrow I will get all the cables and linkage off. |
dakotaewing |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,163 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region ![]() ![]() |
While you are on it... Get the shifter rod off. Remove the clutch cable and the speedo cable...bend gently towards the front of the car and under the car...no kinking. Pull the throttle cable down below and put it with the clutch cable. From there...30 minutes and two beers...we are done. Rich OK Rich I will get the cables out and the shift rod. What kind of beer do you like?Im on this kick where i have been drinking misro brews.But I like any beer. So tomorrow I will get all the cables and linkage off. Make sure to disconnect the axles/CV's at the tranny while you are at it, if you have the proper tools... If you don't have the proper tools, wait on Rich... (IMG:style_emoticons/default/blink.gif) |
Lo-Fi Version | Time is now: 1st August 2025 - 06:11 AM |
