turnaround89 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest ![]() |
This may be a really dumb question, but the front end of my car really need to be lowered and the adjusters are rusted stuck. Ive tried everything, penetrating oil for days on end, locking pliers, bolt out on a ratchet. the allen is rounded out as well which makes matters worse. I saw a picture of the torsion bar and adjuster out of an a arm, is it possible to pull the torsion bar and adjuster or should i just pull the whole a arm off to work on the adjuster part?
If i pull the a arm, i take it that means i need a front end alignment done, right? Heres the picture i saw, that made me wonder if the adjuster and torsion bar can come out with the a arm still attached to the car jmmotorsports = i hope you don't mind me using your picture for some help (IMG:http://www.914world.com/bbs2/uploads/post-6658-1246635808.jpg) |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The manuals for the 911 that uses the same wedge pin and ball joint arrangement always refer to that as "Wedge Pin (always replace)". I say take an air chisel to the thing and replace it when you re-install.
You can drill a hole in the front torsion bar retainer and use a big punch and hammer the s**t out of it to drive the torsion bar toward the rear of the car. --DD |
Lo-Fi Version | Time is now: 5th July 2025 - 08:55 PM |
