> swap out 1.8 to 2.0 all stock 1974 914, no start not getting fuel wtf
Tman914
post Jul 5 2009, 11:56 PM
did this swap 1.8 to 2.0 all stock 1974 914 install the fuel pump relays ,check fues's as well add alittle gas down the carb and it runs . I have two gallons of gas in the tank
my fuel pump is not comeing when i trun the key, I jump it out and it comes on but no power to it swap out relay's still no action removed fuel relay and check wire pin 87 at relay and grounded pin 85 wire got 12 volts the book said the pump is bad i dont think this right after jumpimg it out and it came on but did not start when i jump it out .
(IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif)
Tman914
post Jul 6 2009, 10:07 AM
Ya its the DJet injection system that came with the 2.0
ArtechnikA
post Jul 6 2009, 10:31 AM
rich herzog
QUOTE(Tman914 @ Jul 6 2009, 12:07 PM) *
so you have the MPS and the computer that came with the DJet, and you're using them ?
The wiring harnesses are not plug-compatible, because none of the parts are plug-compatible...
- Lo-Fi Version Time is now: 2nd May 2026 - 10:44 AM
