> are these valves bad?, picture attached.
JOE M
post Jul 5 2009, 10:31 AM
Rich,
I tried to add a pic in a p.m I sent you but could not do it. Can anyone tell me if looking at this pic there is an indication if the valves are burned or bad?The car has low compression and is near impossible to tune.The pic is of cylinders 1 and 2. Thanks.
r_towle
post Jul 6 2009, 05:07 PM
Custom Member
I could do this tomorrow if you want....its supposed to rain on Wednesday...and seeing as you have no roof (hint hint)
Tuesday would be better.
I will bring a dolly, and the tools we need to drop it.
Make sure the carbs are off (to high) and put tape over the manifolds...
Or...I bet you removed all that already...so dont worry...
Remove and cap the fuel lines so we dont get all wet....
thats it...
IDK about the beer...your choice.
Rich
JOE M   are these valves bad?   Jul 5 2009, 10:31 AM
Cap'n Krusty   Unless there's a wedge shaped hole where the v...   Jul 5 2009, 11:05 AM
JOE M   Unless there's a wedge shaped hole where the ...   Jul 5 2009, 11:21 AM
9146986   Pull the engine, you'll spend less time doing ...   Jul 5 2009, 11:26 AM
JOE M   Pull the engine, you'll spend less time doing...   Jul 5 2009, 11:30 AM
ericread   Pull the engine, you'll spend less time doin...   Jul 5 2009, 12:02 PM
McMark   How To Drop Your Engine Do it. You'll be sur...   Jul 5 2009, 12:09 PM
ConeDodger   Judging by your pictures, you have already put mor...   Jul 5 2009, 12:13 PM
JOE M   Judging by your pictures, you have already put mo...   Jul 5 2009, 12:43 PM
blitZ   I dont know how long it takes to drop the engine ...   Jul 5 2009, 01:04 PM
r_towle   Judging by your pictures, you have already put m...   Jul 5 2009, 02:35 PM
JOE M   [quote name='JOE M' post='1188598' date='Jul 5 20...   Jul 5 2009, 03:29 PM
SirAndy   I dont know how long it takes to drop the engine ...   Jul 5 2009, 03:16 PM
ConeDodger   The problem with the motorcycle jack comes when yo...   Jul 5 2009, 03:34 PM
JOE M   The problem with the motorcycle jack comes when y...   Jul 5 2009, 03:45 PM
dangrouche   I highly suggest CHris Foley's engine plate, c...   Jul 5 2009, 04:33 PM
r_towle   Tell me what you need. I have a few dollies...dont...   Jul 5 2009, 05:42 PM
r_towle   While you are on it... Get the shifter rod off. Re...   Jul 5 2009, 05:44 PM
JOE M   While you are on it... Get the shifter rod off. R...   Jul 5 2009, 06:35 PM
dakotaewing   While you are on it... Get the shifter rod off. ...   Jul 5 2009, 06:43 PM
JOE M   Thats what led me to trying to remove the heads wi...   Jul 5 2009, 07:04 PM
JOE M   Rich O.K I got all the cables and the shift linkag...   Jul 6 2009, 04:20 PM
r_towle   I could do this tomorrow if you want....its suppos...   Jul 6 2009, 05:07 PM
JOE M   Thanks sounds good. I could do this tomorrow if ...   Jul 6 2009, 06:18 PM
- Lo-Fi Version Time is now: 1st August 2025 - 06:18 AM
