PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,893 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
![]() ![]() New tubes really add to the general fresh look to the front trunk. I had to make a bolt to hold the back of the winshield wiper assembly in place, but I got everything bolted up this weekend. Next comes the wiring in the dash I guess. The wire mess looks a bit overwelming. Any advice is welcome. And yes I know the light switches are out of order ![]() |
racunniff |
volt914 ![]() ![]() Group: Members Posts: 172 Joined: 21-August 06 From: Fort Collins, CO Member No.: 6,705 Region Association: Rocky Mountains ![]() |
The wire mess looks a bit overwelming. Any advice is welcome. And yes I know the light switches are out of order Did you label the wires before you removed the harness? Or is this a new harness? Regardless - my advice on hooking everything back up is "one step at a time." Hook up the fuse panel. And then, one gadget at a time. Identify where you think something should plug in. Ideally, verify your choice with a voltmeter (if you have the switches hooked up). Hook up your gadget. Look/listen/smell for burning wires and blown fuses. Turn the switch on to your gadget. Look/listen/smell for burning wires and blown fuses. Verify proper operation. Move on to the next gadget. On the "burning wires" front - you should probably have quick access to the 12V battery during all this - so you can quickly disconnect if you start overheating something. I kept mine outside the car hooked up via jumper cables. Most of the wires are *not* fuse-protected (especially grounds) and they can smoke very very quickly. |
racunniff |
The wire mess looks a bit overwelming. Any advice is welcome. And yes I know the light switches are out of order ...my advice on hooking everything back up is "one step at a time." One more thing - sand all the paint and primer off of all the ground points before attaching ground wires. If you are worried about corrosion, drop a bit of dielectric grease on each one before plugging in the wire. |
Lo-Fi Version | Time is now: 5th June 2025 - 10:12 PM |
