PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,893 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
![]() ![]() New tubes really add to the general fresh look to the front trunk. I had to make a bolt to hold the back of the winshield wiper assembly in place, but I got everything bolted up this weekend. Next comes the wiring in the dash I guess. The wire mess looks a bit overwelming. Any advice is welcome. And yes I know the light switches are out of order ![]() |
FourBlades |
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States ![]() ![]() |
I found that laying out the wiring in the car gives you a general idea what
device the wires should go to. The wires are all about the right length to get where they need to be without a lot of extra length. Get a color diagram from Prospero's Garage. It is easier to read than the hanes B&W pictures and it is laminated and sweat proof. I think I got mine on ebay. ![]() Here's some tips from an OLDE WORLDE mechanic that I plan to use pretty soon when I finally hook up a battery to the car. Put a 3 amp fuse between your battery and the positive wires. That way the fuse will blow if you have a short instead of cooking your wiring. Take all the fuses and relays out except the one for the circuit you are debugging. Add them back one at a time as you work through the systems. I have nearly all my wiring hooked up so we'll see soon how I did. John |
watsonrx13 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States ![]() |
I found that laying out the wiring in the car gives you a general idea what device the wires should go to. The wires are all about the right length to get where they need to be without a lot of extra length. Get a color diagram from Prospero's Garage. It is easier to read than the hanes B&W pictures and it is laminated and sweat proof. I think I got mine on ebay. ![]() Here's some tips from an OLDE WORLDE mechanic that I plan to use pretty soon when I finally hook up a battery to the car. Put a 3 amp fuse between your battery and the positive wires. That way the fuse will blow if you have a short instead of cooking your wiring. Take all the fuses and relays out except the one for the circuit you are debugging. Add them back one at a time as you work through the systems. I have nearly all my wiring hooked up so we'll see soon how I did. John John, I've been looking for these large laminated print outs for awhile.... Anyway, here's the link to Prospero's Garage, unfortunately they only have the diagrams from 70-73 for now.... BTW, the installation of the fresh air system looks great.... (IMG:style_emoticons/default/aktion035.gif) -- Rob |
Lo-Fi Version | Time is now: 5th June 2025 - 10:12 PM |
