> two "quick" six conversion questions....
Scott S
post Jul 7 2009, 02:59 PM
Small Member
Hi All -
I did some searching, but nothing came up...
I have two quick (yeah, right...) conversion questions. Does anyone have a step by step for the wiring on a six conversion? Have seen cars both with and without the relay board -not quite sure how it all should go. This will be for a carbed motor. My 2.0 4cyl is carbed and the relay board is still intact.
Also, I want to keep my front mounted oil cooler. I plan on using Rich Johnsons modified stock oil cooler and hopefully (depending on budget restraints) his reproduction GT oil lines. Just not sure what gets hooked to what in terms of inlet and outlet.
Thanks!!!
Scott S
Justinp71
post Jul 8 2009, 02:26 PM
Make sure that your oil cooler is atleast AN-12, if its any smaller you can't use it.
The early 911 alternator still uses a regulator, I'm not sure if they can be wired the same as the 914 alternator. The later alternators (I think 3.0 motors and newer) have the internally regulated alternator and require different wiring, but they are pretty easy to figure out. Also note that the internally regulated alternator uses a different cowling (the piece that goes behind the alternator).
Good Luck! (IMG:style_emoticons/default/biggrin.gif)
- Lo-Fi Version Time is now: 29th April 2026 - 07:57 PM
