Porsche Rescue |
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None ![]() |
Started my '70 tail shifter this morning, attempted to engage reverse and heardf/felt a horrible grind (kind of like the clutch pedal was not depressed, but it was). Quickly returned to neutral and tried again. I engaged reverse OK and backed out of the garage. But I heard a grinding/growling noise while moving and felt the sensation of something restricting movement (like brake on, but it wasnt'). Moved it back and forth in the driveway in all gears. It makes the same noise in all 5 forward gears as soon as I release the clutch. Reverse now seems almost OK.
Where do I start? Could it be a linkage issue (the front two bushings were new a few months ago)? It shifts smoothly when clutch pedal is depressed. Is something broken in the tranny? All opinions welcome. |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
Everything I can see looks very nice & turns smooth & free...including the gears on needle bearings. The ring & pinion are smooth as a baby's ass. I haven't had time to disassemble the shafts and I'm off to play with the SCCA for a 3 day weekend. I probably won't get back to it till next weekend.
Jim also brought by his clutch and it didn't look too shiney. He said the flywheel looked worse. The noise seemed to be a rotational sound but he said the clutch wasn't slipping. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 1st August 2025 - 04:14 AM |
