djm914-6 |
Happiness is: Getting on the road ![]() ![]() ![]() Group: Members Posts: 1,864 Joined: 6-February 03 From: Burlington MA Member No.: 248 Region Association: None ![]() |
So I got these really cool speakers and housings in the mail the other day. Morph does a great job! I just ordered a Blauplunkt radio to go with them. Now I need to figure out how to hook it up. I know there are a couple of wired zip-tied under the dash, I'll try to figure out where they go and see if thay once powered a radio. If not, then what? Also, can one hide an antenna somewhere?
Any help on wires, installs, etc would be great. Thanks, David |
zonedoubt |
Canadian Member ![]() ![]() ![]() Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada ![]() |
Not much to it really, I would run new wiring rather than relying on previous radio wiring, who knows what kind of hack job a PO did.
+12V switched power from the fuse box. A pair of speaker +/- wires and away you go. If the radio is new, it may have a "memory" wire so that needs constant +12. Heck, if the radio is new, then you should have a wiring diagram to follow in the user's manual. |
djm914-6 |
Not much to it really, I would run new wiring rather than relying on previous radio wiring, who knows what kind of hack job a PO did. +12V switched power from the fuse box. A pair of speaker +/- wires and away you go. If the radio is new, it may have a "memory" wire so that needs constant +12. Heck, if the radio is new, then you should have a wiring diagram to follow in the user's manual. Monster cable should work for car speakers to? I have a bunch left over from my old home theater. I really wish i cold read that 6 cyl wiring diagram better to see what's switch and what's constant. Time to plot it off in a larger scale and study it for awhile. |
Lo-Fi Version | Time is now: 1st August 2025 - 01:54 PM |
