> so close.. 2.0 weber 44s drives and misses
gotxqss
post Jul 9 2009, 09:20 PM
So did some searching.. Did some reading.. Have had this car for awhile and finally got off the ass to start tinkerin!
Cars a 75 with a 2.0 from another car.. Could be stock could be rebuilt I have no clue.. Guessing its a stock or mildly touched motor.. I had a buddy come over and get it idling pretty good.
Set float levels
Cleaned and put back together
Set linkage that sorta stuff
Just a quik list of the main parts as there might be a section that's just flatout needs attention .
Weber 44idf
32 venturi
175 air (I think these need to be higher?)
55 idles
F11 et
140 main
So anyway hopefully 1 of those things will standout to try to get me closer..
Haven't driven the car alll that much but from what I have. It will idle and rev well, the super low speed low rpm stuff feels decent but the midrange has stumbles. At a steady cruise it will pop as well. If I get in the gas pretty hard down low(under 2500rpm) it will be pretty dead till about 4k and then pulls really well to 6k.
So of course something is off but I don't have a weber guru here in vegas that I know of that can just handle it so now im asking for help..
Maybe there are some things that im missing to get me closer..
I do have 50 idles and 135 mains laying around..
Thanks guys.. Ill keep up and get this handled!!!!!!
jmill
post Jul 11 2009, 11:57 AM
Green Hornet
When running the larger vents on a smaller engine you have less velocity through the carb. Less velocity equals less DP on the jets. Which basically means you have less suction pulling fuel into the throat of the carb. You can compensate for this by running larger mains and idles. You can get it to work but lousy MPG is one of the side effects.
- Lo-Fi Version Time is now: 17th July 2025 - 09:03 AM
