ebrake parts, Can you find the part number??? |
partsman |
Jun 16 2009, 08:05 PM
forever hooked Group: Members Posts: 276 Joined: 27-February 04 From: Bradford, MA Member No.: 1,726 Region Association: North East States |
I'm trying to finally hook up my ebrake after ten years of not having one (ok, I had one for a while but it was frozen..then I removed everything when I replaced the floors..) so now, I'm looking at the parts diagrams, and trying to see where everything goes..
I know the two cables come through the rear firewall, and hook to an equilizer, that hooks to a short cable that goes to the lever... here's my two questions: The parts diagram shows a small plate that is attached to the equilizer... and has one end hooked to a spring.. where does this spring hook to.. the rear firewall? Does this provide the return tension when you release the brake.. I found a small sprin in the box that I put all the handbrake stuff in, but no plate.. How does the small cable hook to the lever.. at the lower most hole, or does it hook to the flat plate with teeth on it that is inside the lever? Any help would be appreciated. Thanks, Eric |
william harris |
Jul 14 2009, 05:45 PM
914 Restorer Group: Members Posts: 1,459 Joined: 9-January 04 From: Hamilton, MA Member No.: 1,539 |
Eric: Now that I went into my stash of stuff and found that plate that doesn't even exist on the parts diagram, show some pictures of what the parking brake looks like now. (IMG:style_emoticons/default/shades.gif)
Attached image(s) |
Lo-Fi Version | Time is now: 9th June 2024 - 05:20 AM |
