ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
From the Forester Thread:
I have a '97 EJ25D (~165HP stock) core engine available. The only part of the engine I'm iffy on is the heads may be warped. I donno. - they don't seal to the water jacket when hot, but it'll idle all day long. Complete less a few trinkets - my replacement engine came without the stupid hose to the throttle body and I pulled the engine _again_ thinking it was some cylinder seal issue (but it was easier to replace the stupid hose with the engine out...). And the EGR valve on the replacement was squashed so I cannibalised it from the original. Everything else is in 'as-removed' condition. I will deliver within a hundred mi or so of SEPA - I'm changing storage units and I have to move it _somewhere_ - it's just a matter of how far it goes before being unloaded... It's basically a long block with induction. You might have to resurface or replace heads (i'm told there is not much material for resurfacing these heads) but everything else is there. |
Gigamight |
Member ![]() ![]() Group: Members Posts: 220 Joined: 8-June 09 From: Near Akron, Ohio Member No.: 10,454 Region Association: Middle East ![]() |
From the Forester Thread: I have a '97 EJ25D (~165HP stock) core engine available. The only part of the engine I'm iffy on is the heads may be warped. I donno. - they don't seal to the water jacket when hot, but it'll idle all day long. Complete less a few trinkets - my replacement engine came without the stupid hose to the throttle body and I pulled the engine _again_ thinking it was some cylinder seal issue (but it was easier to replace the stupid hose with the engine out...). And the EGR valve on the replacement was squashed so I cannibalised it from the original. Everything else is in 'as-removed' condition. I will deliver within a hundred mi or so of SEPA - I'm changing storage units and I have to move it _somewhere_ - it's just a matter of how far it goes before being unloaded... It's basically a long block with induction. You might have to resurface or replace heads (i'm told there is not much material for resurfacing these heads) but everything else is there. Very generous offer you have there. Where are you exactly, I am near Akron, Ohio. |
ArtechnikA |
Very generous offer you have there. Where are you exactly, I am near Akron, Ohio. Call it Philadelphia. 400 mi each way, 6-1/2 hours. More than I can afford to do for free. I'm glad to work with you on the logistics but that's a bit more than a daytrip for me, and at 16 mpg, about $125 in gas alone... |
Lo-Fi Version | Time is now: 16th June 2024 - 12:10 PM |
