| ME733 |
Jul 5 2009, 12:00 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
You have asked about the fuchs which came on my 914 S....here goes...the O.E.M. spare rim is dated 8-72...and so are all the others.....and they are part#...914.361.011.00 .They look different in /on the backside than THE PHOTOGRAPH with notes you have shown......as a point of intrest the spare RIM and ALL the four on the ground are identical in every way...EXCEPT the four on the ground have a Painted BACKGROUND.....and after looking closely with a magnifing glass its obvious they are painted...and not quite dead flat black....they are Not anodized....the spare tire is an original tire ..DUNLOP 165 hr 15....looks like it and the rim have NEVER been used...the rim is clean and perfect (both sides and the tire has full tread....and is not dry rotted.(cracks showing in sidewalls)..However,.I would never consider using it obviously. (IMG:style_emoticons/default/bye1.gif)
| McMark |
Jul 7 2009, 07:12 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
QUOTE the anodizing is a heat tempering process Anodizing in an electrical process involving cathode/anode interactions in a chemical bath. Heat isn't a significant part of the process. Anodizing makes the surface harder and impervious to oxidation. After anodizing, but before sealing, a dye can be sprayed, dipped, or brushed onto the part to color it. |
| Tom_T |
Jul 7 2009, 10:21 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
QUOTE the anodizing is a heat tempering process Anodizing in an electrical process involving cathode/anode interactions in a chemical bath. Heat isn't a significant part of the process. Anodizing makes the surface harder and impervious to oxidation. After anodizing, but before sealing, a dye can be sprayed, dipped, or brushed onto the part to color it. So McMark - on those 2L alloys - did they color the background to that matte or satin silver finish, then seal them???? (IMG:style_emoticons/default/confused24.gif) If so, what is the correct dye & finish on that background area??? (IMG:style_emoticons/default/confused24.gif) ...as opposed to the semi-polished "petals" or "windmill blades" & rims or lips below: ![]() |
| McMark |
Jul 22 2009, 04:22 PM
So McMark - on those 2L alloys - did they color the background to that matte or satin silver finish, then seal them???? ...as opposed to the semi-polished "petals" or "windmill blades" & rims or lips below: The 'color' difference in this case is a factor of pre-anodizing surface finish. Anodizing is not thick and so will 'show through' any finish on the base metal. Anodizing does reduce any polish slightly, and that's why aluminum trim will never be as reflective as chrome trim. The difficulty in refinishing wheels like this is how to reproduce a non-directional satin finish. Bead blasting is too coarse, sanding leave directional scratches, but perhaps something like soda blasting would work (or some other media, maybe plastic?). Al Reed certainly has this down. He did a set of RS-look five lugs for me that were perfect (RS-look is just like ours, satin background with polished spokes/paddles). |
ME733 more about Fuchs Jul 5 2009, 12:00 PM
Tom_T Thanx - great info ME733,
Your info proves that t... Jul 5 2009, 04:08 PM
ME733 Tom...this is murray.,,I found your questions intr... Jul 5 2009, 10:55 PM
ME733
Tom...this is murray.,,I found your questions int... Sep 21 2009, 09:29 AM
Tom_T
Tom...this is murray.,,I found your questions in... Sep 21 2009, 02:13 PM
Pat Garvey Two things here, and the post will be moved to the... Jul 6 2009, 08:17 PM
Tom_T BTW Pat -
Because the early hubs were flat ... Jul 6 2009, 10:34 PM
RobW
Anodizing in an electrical process involving cat... Jul 7 2009, 08:50 PM
Pat Garvey
Anodizing in an electrical process involving ca... Jul 7 2009, 09:11 PM
Tom_T
Anodizing in an electrical process involving cat... Jul 7 2009, 09:49 PM
orthobiz
So McMark - on those 2L alloys - did they color ... Jul 11 2009, 10:20 PM
Tom_T
So McMark - on those 2L alloys - did they color t... Jul 22 2009, 04:39 PM
Bleyseng
[quote name='McMark' post='1194209' date='Jul 22 ... Sep 21 2009, 10:35 PM
Tom_T
[quote name='McMark' post='1194209' date='Jul 22... Sep 21 2009, 10:52 PM
Tom_T Listing of several wheel refinishers on both coast... Jul 7 2009, 10:09 PM
Tom_T I suppose the background could be more of a raw un... Jul 11 2009, 11:30 PM
6freak new Fuchs now available through Porsche ...$1... Jul 11 2009, 11:37 PM
Tom_T
new Fuchs now available through Porsche ...... Jul 11 2009, 11:46 PM
6freak
new Fuchs now available through Porsche ...... Jul 12 2009, 12:18 AM
Tom_T
new Fuchs now available through Porsche ...... Jul 12 2009, 12:11 PM
6freak Talk`n bout the 5 lugs.....From Porsche Design... Jul 13 2009, 09:35 AM
Tom_T
Talk`n bout the 5 lugs.....From Porsche Desig... Jul 14 2009, 12:55 AM
6freak If I keep buy`n fancy stuff I`ll never get... Jul 14 2009, 11:06 AM
ME733 :popcorn: Tom...I did ask an expert about the ... Sep 21 2009, 09:20 PM
Tom_T
:popcorn: Tom...I did ask an expert about the ... Sep 21 2009, 10:05 PM
Pat Garvey
:popcorn: Tom...I did ask an expert about the ... Sep 22 2009, 07:32 PM
Bleyseng I have used Wurth's silver as its a close matc... Sep 23 2009, 08:17 AM
ME733 :popcorn: George H at A.A. has the exact wurth col... Sep 23 2009, 11:50 PM
Tom_T
:popcorn: George H at A.A. has the exact wurth co... Sep 26 2009, 06:30 PM
davep In my experience there were 3 front brake rotors u... Sep 25 2009, 09:02 AM
ME733 :popcorn: Hello davep....Intresting obversavions i... Sep 25 2009, 08:26 PM
Tom_T Yes Murray, the Fuchs 2L were listed as "Forg... Sep 26 2009, 01:46 PM
ME733 :popcorn: TOM, ..Is this of any intrest?...my O.E.... Oct 2 2009, 12:13 PM
Tom_T
:popcorn: TOM, ..Is this of any intrest?...my O.E... Oct 2 2009, 03:43 PM
ME733 :popcorn: ...YES TOM this information does help...... Oct 3 2009, 08:03 AM
Tom_T
:popcorn: ...YES TOM this information does help..... Oct 3 2009, 10:56 AM
Jeff Bowlsby The correct link for the recall info is now: http... Oct 4 2009, 10:19 AM
Tom_T
The correct link for the recall info is now: htt... Oct 4 2009, 10:58 AM
Jeff Bowlsby Hi Tom, I did post the website links update a wee... Oct 5 2009, 02:49 PM
Tom_T
Hi Tom, I did post the website links update a we... Oct 5 2009, 03:54 PM
ME733 :popcorn: ...TOM...So in my wonderment ..about WHY... Oct 4 2009, 11:52 AM
Tom_T
:popcorn: ...TOM...So in my wonderment ..about WH... Oct 4 2009, 07:55 PM
ME733 :popcorn: TOM...the ...FUCHS forged wheels..(just... Oct 4 2009, 08:43 PM
Tom_T
:popcorn: TOM...the ...FUCHS forged wheels..(jus... Oct 4 2009, 10:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:58 PM |
