Blueprinting an Oil Pump, Looking for a good article to do this |
E-Man |
Jul 22 2009, 11:03 PM
Member Group: Members Posts: 158 Joined: 4-March 03 From: S. Windsor, CT Member No.: 390 |
I recall seeing an article on this in the past but cannot locate it. Any help?
McMark |
Jul 23 2009, 10:30 AM
Measure the distance between the gear tops and the top of the aluminum housing (where the cover sits). If you don't get 0.005" (IIRC) then take the gears out, find a thick piece of glass and get some sandpaper. The glass will give you a true flat surface, put the sandpaper down and sand in a circular motion to remove material from the aluminum housing (where the cover sit). Check often since it's easier to remove material than replace it. (IMG:style_emoticons/default/wink.gif)
E-Man |
Jul 23 2009, 11:13 AM
Thanks! That's what I remember reading (except for the .005). -Mike
Lo-Fi Version | Time is now: 1st June 2024 - 11:17 AM |
