> Show me your dual carburetors setup
schreiber
post Aug 1 2009, 06:14 PM
In this thread: Show pictures of your dual Weber setups. The more detail, the better.
t collins
post Aug 2 2009, 10:18 AM
Attached ImageMy Dells
VaccaRabite
post Aug 2 2009, 02:39 PM
En Garde!
QUOTE(t collins @ Aug 2 2009, 11:18 AM) *
How did you do this? Drill and tap the arms?
I need to do the same thing with mine.
Zach
r_towle
post Aug 2 2009, 03:19 PM
Custom Member
QUOTE(Vacca Rabite @ Aug 2 2009, 04:39 PM) *
Zach
That is a bell crank linkage and it uses the ball on the carb linkage.
RIch
VaccaRabite
post Aug 2 2009, 09:14 PM
En Garde!
QUOTE(r_towle @ Aug 2 2009, 04:19 PM) *
I know that, silly. (IMG:style_emoticons/default/biggrin.gif) I've got the same linkage. The issue is that the bar between the linkage and the carb butterfly lever is at an angle. In fact, they are at slightly different angles. If you use the provided holes in the linkage arms, you will not get a 90 degree drop on either side, and the carbs don't stay perfectly synched through the rev range.
Zach
t collins
post Aug 3 2009, 05:23 AM
QUOTE(Vacca Rabite @ Aug 2 2009, 07:14 PM) *
Zach
They're both parallle, its just the angle of the picture that is making it look out of plumb.
schreiber   Show me your dual carburetors setup   Aug 1 2009, 06:14 PM
tat2dphreak   this is how a bad setup looks... unfortunately, it...   Aug 1 2009, 06:18 PM
Scott Schroeder   mine ...   Aug 1 2009, 07:25 PM
r_towle   mine ... Scott, I know this is a pain to do, bu...   Aug 2 2009, 01:07 PM
MDG   here's my dual webers :)   Aug 1 2009, 08:22 PM
zymurgist   here's my dual webers :) I see what you...   Aug 2 2009, 09:11 AM
MDG   I see what you did there. :driving: What . . ...   Aug 2 2009, 11:00 AM
craig downs   Here some dual Dells   Aug 2 2009, 01:03 AM
schreiber   I'm interested in seeing these type linkage ...   Aug 14 2009, 10:15 PM
pilothyer   I'm interested in seeing these type linkage...   Aug 18 2009, 08:19 AM
tat2dphreak   [quote name='schreiber' post='1203045' date='Aug ...   Aug 18 2009, 10:55 AM
t collins   My Dells   Aug 2 2009, 10:18 AM
Vacca Rabite   My Dells How did you do this? Drill and tap the...   Aug 2 2009, 02:39 PM
r_towle   My Dells How did you do this? Drill and tap th...   Aug 2 2009, 03:19 PM
Vacca Rabite   How did you do this? Drill and tap the arms? I...   Aug 2 2009, 09:14 PM
t collins   [quote name='r_towle' post='1198429' date='Aug 2 ...   Aug 3 2009, 05:23 AM
t collins   My Dells How did you do this? Drill and tap th...   Aug 2 2009, 06:39 PM
rfuerst911sc   Here are mine. :D   Aug 2 2009, 01:22 PM
J P Stein   Hee.hee, I can play. Real carbs have 3 throats. :D   Aug 2 2009, 01:50 PM
r_towle   Hee.hee, I can play. Real carbs have 3 throats. :...   Aug 2 2009, 03:20 PM
J P Stein   Hee.hee, I can play. Real carbs have 3 throats. ...   Aug 2 2009, 09:01 PM
zx-niner   Here's a before and after.   Aug 2 2009, 02:21 PM
carr914   RE: Show me your dual carburetors setup   Aug 2 2009, 08:37 PM
carr914   RE: Show me your dual carburetors setup   Aug 2 2009, 08:39 PM
puff adder   50's   Aug 2 2009, 08:48 PM
racerbvd   RE: Show me your dual carburetors setup   Aug 2 2009, 09:21 PM
carr914   Byron, What are those Dizzy's you've got o...   Aug 2 2009, 09:29 PM
racerbvd   Byron, What are those Dizzy's you've got ...   Aug 2 2009, 09:34 PM
neil30076   In this thread: Show pictures of your dual Weber ...   Aug 3 2009, 10:13 AM
Kargeek   Dells with reversed CB crossbar linkage.   Aug 3 2009, 01:28 PM
naro914   PMO's in Huey (now in Papa Smurf)   Aug 3 2009, 04:56 PM
Mark Henry   Cargeeks is the best linkage so far, but still a b...   Aug 5 2009, 11:39 AM
martinef1963   This car ran for about 5-minutes after the engine ...   Aug 16 2009, 06:11 AM
tat2dphreak   This car ran for about 5-minutes after the engine...   Aug 16 2009, 09:10 AM
lotus_65   link someone here makes a nice pivot linkage I...   Aug 16 2009, 10:29 AM
jmill   The issue is that the bar between the linkage a...   Aug 16 2009, 10:58 AM
jaxdream   I believe that is called the sidewinder linkage ki...   Aug 16 2009, 11:37 PM
Dominic   Picture of my DTM bell crank linkage from Aircoole...   Aug 18 2009, 08:36 AM
lotus_65   Picture of my DTM bell crank linkage from Aircool...   Aug 18 2009, 06:46 PM
Cevan   CIP1 linkage   Aug 18 2009, 09:51 AM
pilothyer   Hi Wayne......I believe that was a pair of Weber 3...   Aug 18 2009, 01:03 PM
tat2dphreak   ahh, ok.   Aug 18 2009, 01:17 PM
r_towle   Take a look at some artwork here. http://www.yuni...   Aug 18 2009, 02:36 PM
Mr.Nobody   Bump, because I want to see more peoples setups. ...   Apr 21 2016, 06:07 PM
ThePaintedMan   This is going to sound like a total dick comment, ...   Apr 21 2016, 06:36 PM
Mr.Nobody   This is going to sound like a total dick comment,...   Apr 21 2016, 11:03 PM
bretth   How about my Zeniths just because. Hope to put the...   Apr 21 2016, 07:46 PM
poorsche914   NOS 44IDF Webers with Raby Sync-Link :driving:   Apr 21 2016, 09:23 PM
raw1298   Not sure of brand, but it was free. :D   Apr 21 2016, 09:52 PM
Elliot Cannon   No play in the linkage. Both throttles open to wo...   Apr 21 2016, 11:47 PM
era vulgaris   DRLA40'S on a 2270   Apr 22 2016, 12:33 PM
Starlack   OK here is a Picture of my Engine with Weber Carb...   Apr 22 2016, 12:57 PM
MarkV   RE: Show me your dual carburetors setup   Apr 22 2016, 02:29 PM
jacquot   dual weber 44 idf, overall throttle cable from...   Apr 25 2016, 01:36 PM
forrestkhaag   /The beauty of this system is simplicity and three...   Apr 25 2016, 02:13 PM
- Lo-Fi Version Time is now: 30th October 2026 - 11:53 PM
