QUOTE(ThePaintedMan @ Apr 21 2016, 05:36 PM)
This is going to sound like a total dick comment, but I promise I don't mean for it to....
Dellorto air cleaner covers but Weber carbs?
FWIW, I will tell you after having seen a few of these after all the rebuilds I've done... The chrome air cleaners, I mean, every. last. one. of them. I've seen rusts within 2-3 months. I don't personally care much about looks, but I know there are better options out there, in case you do. Finally, if you have a hard time with that hex bar linkage, consider Chris's cable linkage setup which can be found on his website, tangerineracing.com. Once you switch you'll wonder how you ever did without it. Not trying to dissuade you, just giving you a couple things I learned the hard way. Rock on!
Not a dick comment at all. I get your thoughts.
The Del filters just happen to have been apart of a really good deal with the carbs, and linkage. They'll work and really that's all that should matter, but I agree it's pretty hokey to run them with the Webers. I have another plan for them if I can't find another set soon enough. In short, hopefully they're temporary.
I've read a lot about the Tangerine setup. It's on the list, but dropping the coin now isn't the easiest. I get that I'll never look back, but buying it is easier said than done. Another hopefully sooner rather than later.
All that said, I'M STOKED
