/The beauty of this system is simplicity and three-way redundant throttle return springs to eliminate the possibility of an over-rev.... (Ask Larmo about the single spring failure.......) one spring at each carb and one in the center of the cable attachment area.
Also, when tuning the carbs one screw takes all pressure off the linkage on both carbs and the same screw puts it all back together when all is balanced.
