> help me ID my 914/4, 1972 porsche 914/4
john914/4
post Aug 5 2009, 09:44 AM
I purchaced a 1972 porsche 914/4 a few weeks back and am having a bit of trouble getting the numbers broke down. the VIN is 4722919064. it was manufactured on 06/72. the karman plate in the drivers door reads NR. 2439512. L9H. the engine was out of the car and it has a number stamped onto the block AW009121. there was a set of webers with it and I found the following on them 40 IDF 19. ? the car seems very original with very minamal rust. it cam from michigan. the color is a gold color under the red paint. I bought a 1970 914/4 a few months before I ran into this one and being the other (1970) is body is completely rusted I am going to use it for parts. I have purchaced a number of books on the 914 and some kind of point me in a direction but not very through. I am under the impresion that this is a 1800 VW bus engine. and maybe a off color. I am prepairing to rebuild the engine and I want to be able to get the correct parts. will these webers work? any help would be very greatly appeciated. this is my first porsche/VW 914. I have a 1972 El camino restored by myself so I do know cars. but these little guys are a mystery right now. thanks for reading. before I leave one more thing that I thought was interesting is the front of this 914 has no grills for the driving lights and is rounded unlike the flat fronts of all the 914's I have seen below the rubber bumper its plain and rounded (2 piece).
tat2dphreak
post Aug 5 2009, 09:58 AM
stoya, stoya, stoya
1st (IMG:style_emoticons/default/welcome.png)
2) AW engine code is a 73-1975 1.8 from a bus. are you getting the number from by the oil filler? just to be sure.
http://www.type2.com/bartnik/enginecodes.htm
3) your VIN is a "late" 72...
The factory changed the strut housing, ball joint, caliper and rotor at VIN 4722919032, so when you go to buy parts, buy a 73 part, not a 72... mine is the same way, and every "70-72" part I've ever bought had to go back for the 73-74 version
4) dual weber 40idfs are a common carb replacement for the factory FI.
post pics, please it probably just lost the grills, but I don't know what you mean about it being flat
john914/4
post Aug 5 2009, 03:50 PM
[quote name='tat2dphreak' date='Aug 5 2009, 07:58 AM' post='1199589']
[quote]before I leave one more thing that I thought was interesting is the front of this 914 has no grills for the driving lights and is rounded unlike the flat fronts of all the 914's I have seen below the rubber bumper its plain and rounded (2 piece).[/quote
below the front bumper is 2 metal panals with no openings. the lower panal has 2 small dimples and thats it. I have not seen these on any other 914 I have looked at. I take it when I get parts for this car I can refere to it as a 73, 1.8 liter VW bus engine? are these considered the opossed cylinder flat motor type 4. are th 40 idf's worth installing and is there rebuild kits for them.
[/quote]
john914/4   help me ID my 914/4   Aug 5 2009, 09:44 AM
type47   Welcome! :wttc: According to this site: http...   Aug 5 2009, 09:54 AM
rick 918-S   :wttc: Yes it's a 72. Someone here has the pa...   Aug 5 2009, 09:55 AM
SirAndy   Someone here has the paint codes listed someplace...   Aug 5 2009, 11:59 AM
john914/4   Someone here has the paint codes listed someplac...   Aug 5 2009, 03:38 PM
john914/4   Someone here has the paint codes listed someplac...   Aug 5 2009, 03:41 PM
Sleepin   19064th 914 built in 1972 Engine number not sure,...   Aug 5 2009, 09:56 AM
tat2dphreak   1st :wttc: 2) AW engine code is a 73-1975 1....   Aug 5 2009, 09:58 AM
john914/4   1st :wttc: 2) AW engine code is a 73-1975 1...   Aug 5 2009, 03:50 PM
Ferg   Cool, another Gold one, to bad it was color change...   Aug 5 2009, 12:06 PM
john914/4   Cool, another Gold one, to bad it was color chang...   Aug 5 2009, 03:34 PM
jt914-6   Andy, Here's a pic of my car's color tag....   Aug 5 2009, 12:34 PM
SirAndy   Here's a pic of my car's color tag. I see...   Aug 5 2009, 08:45 PM
john914/4   Here's a pic of my car's color tag. I se...   Aug 6 2009, 09:05 AM
tat2dphreak   the carb rebuild kits are readily available, I r...   Aug 5 2009, 04:16 PM
john914/4   the carb rebuild kits are readily available, I ...   Aug 6 2009, 09:16 AM
tat2dphreak   well, you will need to replace the crank and rods ...   Aug 6 2009, 09:55 AM
john914/4   well, you will need to replace the crank and rods...   Aug 7 2009, 03:25 PM
john914/4   well, you will need to replace the crank and rod...   Aug 7 2009, 03:40 PM
john914/4   [quote name='john914/4' post='1200588' date='Aug 7...   Aug 7 2009, 03:56 PM
Cupomeat   Wayne, I don't know about you, but I only get ...   Aug 6 2009, 12:32 PM
tat2dphreak   no, you get your porno in 4 minute increments, th...   Aug 6 2009, 01:17 PM
john914/4   [quote name='john914/4' post='1199580' date='Aug 5...   Aug 7 2009, 03:55 PM
tat2dphreak   I think you are talking about the stock Valance be...   Aug 7 2009, 04:08 PM
john914/4   I think you are talking about the stock Valance b...   Aug 8 2009, 08:30 AM
Pat Garvey   Where the heck did that front bumper come from? Pa...   Aug 7 2009, 05:47 PM
tat2dphreak   Where the heck did that front bumper come from? P...   Aug 7 2009, 06:22 PM
john914/4   Where the heck did that front bumper come from? ...   Aug 20 2009, 09:08 AM
tat2dphreak   dunno. stock console had oil temp, voltage and a c...   Aug 20 2009, 09:32 AM
john914/4   dunno. stock console had oil temp, voltage and a ...   Aug 26 2009, 10:37 AM
tat2dphreak   [quote name='tat2dphreak' post='1204882' date='Au...   Aug 26 2009, 11:13 AM
Cupomeat   Nah, leave the boost gauge and wire it so that upo...   Aug 26 2009, 10:52 AM
Grelber   Why not just add extra gauges? There's plenty...   Aug 26 2009, 12:44 PM
- Lo-Fi Version Time is now: 24th June 2026 - 08:22 AM
