911 Valve Adjusters for my Type-4 2.0L?, Good Idea or Bad Idea? |
ericread |
Jul 30 2009, 03:49 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Somewhere earlier I saw a comment that Jake had recommended using 911 Valve Adjusters in the Type-4 engine... Or maybe he had recommended against it. I can't remember.
Anybody out there have experience in this? My adjusters and adjuster nuts were pretty gnarled when I got my car a few years ago. Now with bi-monthly adjustments, I'm looking to replace them. Will the 911 adjusters fit the existing rocker arms? Do I need the same nuts? If I go ahead with this, should my properly adjusted valves run quieter? And is there any advantage to replacing the springs? As a result of some moderate leaky valve guides, my plans are to have the heads re-built this winter. Should I wait until the heads are rebuilt, or is there any reason I shouldn't go ahead with the adjusters, nuts and springs right now? Any thoughts? My thanks. Eric Read |
craig downs |
Aug 5 2009, 07:34 PM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
As Jake mentioned you need to check it. You are making a change in the valve train and your assuming the valve geo is going to be right and if you don't check it you'll never know. The .060 you remove from under the rocker is only a starting point as most of the time its enough but sometimes you need to remove a bit more or shim the rocker shafts but you'll never know unless you check it. Even though you can achieve proper valve lash your geometry could be off.
Lo-Fi Version | Time is now: 8th June 2024 - 03:27 PM |
