| john914/4 |
Aug 5 2009, 09:44 AM
Member ![]() ![]() Group: Members Posts: 52 Joined: 5-August 09 From: Anderson, Indiana Member No.: 10,640 Region Association: Upper MidWest |
I purchaced a 1972 porsche 914/4 a few weeks back and am having a bit of trouble getting the numbers broke down. the VIN is 4722919064. it was manufactured on 06/72. the karman plate in the drivers door reads NR. 2439512. L9H. the engine was out of the car and it has a number stamped onto the block AW009121. there was a set of webers with it and I found the following on them 40 IDF 19. ? the car seems very original with very minamal rust. it cam from michigan. the color is a gold color under the red paint. I bought a 1970 914/4 a few months before I ran into this one and being the other (1970) is body is completely rusted I am going to use it for parts. I have purchaced a number of books on the 914 and some kind of point me in a direction but not very through. I am under the impresion that this is a 1800 VW bus engine. and maybe a off color. I am prepairing to rebuild the engine and I want to be able to get the correct parts. will these webers work? any help would be very greatly appeciated. this is my first porsche/VW 914. I have a 1972 El camino restored by myself so I do know cars. but these little guys are a mystery right now. thanks for reading. before I leave one more thing that I thought was interesting is the front of this 914 has no grills for the driving lights and is rounded unlike the flat fronts of all the 914's I have seen below the rubber bumper its plain and rounded (2 piece).
| tat2dphreak |
Aug 6 2009, 09:55 AM
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
well, you will need to replace the crank and rods to use 2.0L pistons, assuming the 1.8 is still a 1.8, and wasn't rebuilt into something else.
if they are 2.0L pistons the pin height is for a 72mm(2.0) crank, with 2.0 length rods, the 1.8 and 1.7 used a 66mm crank and different rods with different pins. if you are going to build the engine, I suggest getting Jake Raby's build video and studying it like your new favorite porno. you can get it at type4store.com if my engine was in a box of pieces I'd be worried too... (IMG:style_emoticons/default/biggrin.gif) but don't worry, with jake's video, and us here... we'll help |
| john914/4 |
Aug 7 2009, 03:25 PM
well, you will need to replace the crank and rods to use 2.0L pistons, assuming the 1.8 is still a 1.8, and wasn't rebuilt into something else. if they are 2.0L pistons the pin height is for a 72mm(2.0) crank, with 2.0 length rods, the 1.8 and 1.7 used a 66mm crank and different rods with different pins. if you are going to build the engine, I suggest getting Jake Raby's build video and studying it like your new favorite porno. you can get it at type4store.com if my engine was in a box of pieces I'd be worried too... (IMG:style_emoticons/default/biggrin.gif) but don't worry, with jake's video, and us here... we'll help I really appresiate your help and advice. I will check the block and get a new crank and rods if needed. I will also get the vidio. again thanks. |
| john914/4 |
Aug 7 2009, 03:40 PM
well, you will need to replace the crank and rods to use 2.0L pistons, assuming the 1.8 is still a 1.8, and wasn't rebuilt into something else. if they are 2.0L pistons the pin height is for a 72mm(2.0) crank, with 2.0 length rods, the 1.8 and 1.7 used a 66mm crank and different rods with different pins. if you are going to build the engine, I suggest getting Jake Raby's build video and studying it like your new favorite porno. you can get it at type4store.com if my engine was in a box of pieces I'd be worried too... (IMG:style_emoticons/default/biggrin.gif) but don't worry, with jake's video, and us here... we'll help I really appresiate your help and advice. I will check the block and get a new crank and rods if needed. I will also get the vidio. again thanks. I wanted to show you the front of this 914. I have been having a hell of a time figuring out how to download photo's to the site I'll give it a go. |
john914/4 help me ID my 914/4 Aug 5 2009, 09:44 AM
type47 Welcome! :wttc:
According to this site: http... Aug 5 2009, 09:54 AM
rick 918-S :wttc: Yes it's a 72. Someone here has the pa... Aug 5 2009, 09:55 AM
Someone here has the paint codes listed someplace... Aug 5 2009, 11:59 AM
john914/4
Someone here has the paint codes listed someplac... Aug 5 2009, 03:38 PM
john914/4
Someone here has the paint codes listed someplac... Aug 5 2009, 03:41 PM
Sleepin 19064th 914 built in 1972
Engine number not sure,... Aug 5 2009, 09:56 AM
tat2dphreak 1st :wttc:
2) AW engine code is a 73-1975 1.... Aug 5 2009, 09:58 AM
john914/4
1st :wttc:
2) AW engine code is a 73-1975 1... Aug 5 2009, 03:50 PM
Ferg Cool, another Gold one, to bad it was color change... Aug 5 2009, 12:06 PM
john914/4
Cool, another Gold one, to bad it was color chang... Aug 5 2009, 03:34 PM
jt914-6 Andy,
Here's a pic of my car's color tag.... Aug 5 2009, 12:34 PM
Here's a pic of my car's color tag. I see... Aug 5 2009, 08:45 PM
john914/4
Here's a pic of my car's color tag. I se... Aug 6 2009, 09:05 AM
tat2dphreak
the carb rebuild kits are readily available, I r... Aug 5 2009, 04:16 PM
john914/4
the carb rebuild kits are readily available, I ... Aug 6 2009, 09:16 AM
john914/4 [quote name='john914/4' post='1200588' date='Aug 7... Aug 7 2009, 03:56 PM
Cupomeat Wayne, I don't know about you, but I only get ... Aug 6 2009, 12:32 PM
tat2dphreak no, you get your porno in 4 minute increments, th... Aug 6 2009, 01:17 PM
john914/4 [quote name='john914/4' post='1199580' date='Aug 5... Aug 7 2009, 03:55 PM
tat2dphreak I think you are talking about the stock Valance be... Aug 7 2009, 04:08 PM
john914/4
I think you are talking about the stock Valance b... Aug 8 2009, 08:30 AM
Pat Garvey Where the heck did that front bumper come from?
Pa... Aug 7 2009, 05:47 PM
tat2dphreak
P... Aug 7 2009, 06:22 PM
john914/4
... Aug 20 2009, 09:08 AM
tat2dphreak dunno. stock console had oil temp, voltage and a c... Aug 20 2009, 09:32 AM
john914/4
dunno. stock console had oil temp, voltage and a ... Aug 26 2009, 10:37 AM
tat2dphreak
[quote name='tat2dphreak' post='1204882' date='Au... Aug 26 2009, 11:13 AM
Cupomeat Nah, leave the boost gauge and wire it so that upo... Aug 26 2009, 10:52 AM
Grelber Why not just add extra gauges? There's plenty... Aug 26 2009, 12:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th June 2026 - 09:49 AM |
