> New Six Conversion Build Thread
proto31
post Sep 8 2008, 12:21 AM
So, I started my new project (Thomas's old project). The shell was originally aubergine, then painted yellow. Thomas had stripped all the undercoating and removed all the exterior paint. I plan on having the entire shell walnut shell blasted to remove the last of the interior paint. Thomas had also installed the "6" engine mount and the chassis stiffening kit. I have removed the mounting hardware for the window washer tank. This weekend I have started installing the steel AA GT flares. Front and and rear left GT flares were installed. I dismantled the 3.0 engine that I will be using, the heads are off to be rebuilt, the rods balanced, the crank balanced and micro polished, the rockers rebushed and resurfaced, and the flywheel and pressure plate balanced. I'll be running carbs and a 911-01 transmission. More to follow.
jt914-6
post Aug 8 2009, 05:29 AM
Since you are using a 3.0 SC engine with carbs, you should at least have someone like Jerry Woods to recurve the dizzy for carbs. Had mine done and it makes a difference. Also, consider using a MSD 6AL. I'm using that with the Blaster coil, and I've also got the adjustable timing control.
proto31   New Six Conversion Build Thread   Sep 8 2008, 12:21 AM
tronporsche   HHHmmmmm, somethin is telling me this is gonna be ...   Sep 8 2008, 02:49 AM
sww914   Cleco fasteners are good, but this seems like a pe...   Sep 8 2008, 12:00 PM
proto31   Thanks for the Tip! I had the Clacos lying aro...   Sep 8 2008, 01:12 PM
LarryR   Subscribing looks like it will be an interesting b...   Sep 8 2008, 11:41 PM
r_towle   post some more pics... Rich   Sep 9 2008, 07:36 PM
Lou W   This is gonna be a great build, I really liked thi...   Sep 9 2008, 07:52 PM
proto31   So, I finished all the steel flares last weekend. ...   Oct 5 2008, 12:20 AM
proto31   Some more   Oct 5 2008, 12:25 AM
proto31   More And here's one of Thomas working on ...   Oct 5 2008, 12:32 AM
Todd Enlund   Are you going to return the car to Aubergine?   Oct 5 2008, 02:28 AM
rick 918-S   Are you going to return the car to Aubergine? Y...   Oct 5 2008, 09:21 AM
SLITS   Tell that damn Kraut to wear welding goggles befor...   Oct 5 2008, 10:10 AM
Gint   Can't you see the man is trying to get a tan?   Oct 5 2008, 12:32 PM
dakotaewing   Is that beam solid, or rectanglar tubing/channel? ...   Oct 5 2008, 05:11 PM
proto31   I told Thomas to stop staring into the light... Hi...   Oct 5 2008, 07:32 PM
jmill   Adding that beam is a great mod. I like it. I ju...   Oct 5 2008, 08:29 PM
proto31   Here are some photos from Armando Serano's web...   Oct 5 2008, 10:29 PM
ajserrano   Here are some photos from Armando Serano's we...   Jan 16 2010, 12:10 PM
jmill   Thanks for digging those up. Thats just what I wa...   Oct 6 2008, 07:27 AM
proto31   Well, I finally got around to working on my car ag...   Jul 12 2009, 11:36 PM
396   Congrats on your new project!   Jul 13 2009, 01:39 AM
RobW   Neat. Adopt me.   Jul 13 2009, 01:47 AM
nsr-jamie   Cool! Looks like its going to be an excellent ...   Jul 13 2009, 06:37 AM
proto31   Well, I've made a lot of progress over the las...   Aug 6 2009, 05:25 PM
914Sixer   Sweet looking !!!!!!   Aug 6 2009, 05:28 PM
PanelBilly   Your working way too fast.   Aug 6 2009, 07:36 PM
greenie   Your working way too fast. :agree: Looking ...   Aug 6 2009, 07:48 PM
Travis Neff   It's been a little later, where's the pics...   Aug 7 2009, 11:25 AM
proto31   It's been a little later, where's the pic...   Aug 7 2009, 11:31 AM
jt914-6   What cams are you going to use with the carbs?????...   Aug 7 2009, 02:31 PM
proto31   You my friend have taken your 3.0 liter to a whole...   Aug 8 2009, 12:15 AM
proto31   Here's some pics: Seam sealer More Unders...   Aug 8 2009, 01:18 AM
jt914-6   Since you are using a 3.0 SC engine with carbs, yo...   Aug 8 2009, 05:29 AM
proto31   So, here are some updates. I'm extremely happy...   Aug 23 2009, 11:14 PM
proto31   And now for the fun part. I painted the car in my ...   Aug 23 2009, 11:27 PM
proto31   A few more: Here's Thomas helping out wit...   Aug 23 2009, 11:37 PM
Heeltoe914   Very nice job Love the fact that your doing it all...   Aug 23 2009, 11:40 PM
proto31   And finally the car (not the doors and hoods) are ...   Aug 23 2009, 11:48 PM
Travis Neff   :trophy: That looks great!   Aug 24 2009, 01:23 AM
greenie   You are doing fantastic work! Great color...   Aug 24 2009, 10:33 AM
proto31   You are doing fantastic work! Great color...   Aug 24 2009, 06:37 PM
proto31   It's been a few weeks, I've got some updat...   Sep 11 2009, 12:19 AM
proto31   another: Wiring harness installed: Rebuilt p...   Sep 11 2009, 12:27 AM
proto31   another: Rebuilding the shift lever: Installin...   Sep 11 2009, 12:35 AM
proto31   Rebuilding the windshield wiper assembly, zinc pla...   Sep 11 2009, 12:41 AM
rick 918-S   That is going to be one fine car. Nice work.   Sep 11 2009, 07:41 AM
Rod   Fabulous build. Looking forward to see how you pr...   Sep 11 2009, 02:21 PM
proto31   I've got a set of 7 and 8 fuchs that I'll ...   Sep 11 2009, 04:05 PM
AgPete139   Looks good, Dan! Man, you are moving quickly...   Oct 17 2009, 11:10 AM
PanelBilly   Now I told you this before and you're not payi...   Oct 17 2009, 11:40 AM
McMark   Amazing job. I would do charcoal/gray on the whee...   Oct 17 2009, 11:09 PM
pete-stevers   you could do something different for the wheels, l...   Oct 19 2009, 12:32 AM
Gint   Just swipe the wheels off Thomas's car. They ...   Oct 19 2009, 08:02 AM
proto31   Swiping Thomas' wheels would be the easiest ro...   Oct 22 2009, 12:14 PM
proto31   Here's some pics of the beginning of the engin...   Oct 22 2009, 11:08 PM
proto31   The carbs, completely rebuilt, ultrasonically clea...   Oct 22 2009, 11:10 PM
proto31   Rear brake hard lines, with T instead of proportio...   Oct 22 2009, 11:15 PM
proto31   Headlight installation- Rear sway bar (stock)- ...   Oct 22 2009, 11:18 PM
cwpeden   It may have already been mentioned, but I think yo...   Oct 23 2009, 03:11 AM
bcheney   You are doing a VERY nice job with all your work. ...   Oct 23 2009, 05:50 AM
proto31   I got my oil line from Rebel Racing, they are orig...   Oct 22 2009, 11:28 PM
proto31   Here's some previews of the front and rear sus...   Oct 22 2009, 11:35 PM
proto31   Front rotor (picture of just one)- Misc. Cool ...   Oct 22 2009, 11:39 PM
Travis Neff   Bada-bump!   Nov 26 2009, 10:40 PM
Dr Evil   Thanks for the oil hose info. Great build :)   Nov 26 2009, 10:47 PM
geniusanthony   I just went through your thread and I am impressed...   Jan 17 2010, 12:09 AM
proto31   So, a lot of progress has been made since my last ...   Apr 5 2010, 04:05 PM
proto31   Engine installed: Front S Calipers, Thomas and ...   Apr 5 2010, 04:12 PM
proto31   Thomas' sway bar arms, pre-annodizing. These m...   Apr 5 2010, 04:28 PM
AgPete139   Any updates?   Nov 9 2010, 03:20 PM
proto31   Any updates? A few updates, I've already ...   Feb 27 2011, 11:51 PM
proto31   The floorboards:   Feb 27 2011, 11:54 PM
proto31   wheels and gauges...   Feb 27 2011, 11:56 PM
AZ914   :drooley: :drooley: :headbanger:   Feb 28 2011, 07:53 AM
Root_Werks   Man that looks great!   Feb 28 2011, 12:04 PM
proto31   Thanks! It's been a lot of fun so far. Any...   Feb 28 2011, 04:53 PM
Ferg   I vote for brown/brown hounds tooth, or brown with...   Feb 28 2011, 05:23 PM
MDG   I vote for brown/brown hounds tooth Ferg +1 W...   Feb 28 2011, 05:47 PM
proto31   I made a shroud for the front oil cooler, I've...   Mar 4 2011, 11:22 PM
proto31   Some more:   Mar 4 2011, 11:25 PM
speed metal army   Kickass. :notworthy3d: Ive decided to stash ...   Mar 4 2011, 11:56 PM
proto31   Thanks man, I've had a lot of fun building it ...   Mar 6 2011, 12:14 AM
proto31   Dropped the seats, door panels and center armrest ...   Mar 7 2011, 05:02 PM
Ferg   Dropped the seats, door panels and center armrest...   Mar 7 2011, 05:13 PM
MDG   I'm going with Cork (original Porsche color) ...   Mar 7 2011, 06:55 PM
Gint   It's going to be tight for Route 66, may just...   Mar 21 2011, 05:41 AM
Eric_Shea   He just sold it to me. :lol3:   Mar 7 2011, 05:16 PM
Ferg   He just sold it to me. :lol3: Get in line.....   Mar 7 2011, 05:28 PM
proto31   I found some really nice (as close to NOS as you c...   Mar 7 2011, 11:45 PM
proto31   Some more: Installed without bumper, stainless ...   Mar 7 2011, 11:48 PM
proto31   Some updates, Socal Andy came down and polished my...   Mar 20 2011, 09:02 PM
proto31   Thomas' car, a really nice 97' with a GT3 ...   Mar 20 2011, 09:04 PM
proto31   Received all the interior pieces, seats and door p...   Mar 20 2011, 09:08 PM
dw914er   wow!!!!!!!!!...   Mar 20 2011, 09:10 PM
proto31   Installed all the carpet, had to remove the steeri...   Mar 20 2011, 09:14 PM
proto31   Thanks for the comments! Here's the inte...   Mar 20 2011, 09:17 PM
Lou W   Absolutley Stunning. :beer2: :beer2: :beer2:   Mar 20 2011, 09:51 PM
Ferg   Wow :worship:   Mar 21 2011, 08:16 AM
Eric_Shea   :confused: Isn't this car already done? :confu...   Mar 21 2011, 08:48 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:13 PM
