How do I route the windshield waster hose, The lines that run from the steering column |
PanelBilly |
Aug 8 2009, 02:45 PM
914 Guru Group: Members Posts: 5,813 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
The two rubber hoses that come out of the back of the steering wheel. How do they find their way to the spare tire and the two squirters?
r_towle |
Aug 8 2009, 04:41 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
One hose goes to the washer res, bottom outlet.
The other hose goes to a t fitting that is right behind the fresh air box. the other two sides of that t fitting go to the washers. the pressure hose goes from the tire to the top fitting on the res cap. I dont remember where they penetrate the cowl, but use grommets. There is fluid in the line up at the steering wheel. The hose that goes to the tire goes in BEFORE you put in the gas tank..there is a fitting low down on the front wall. Rich |
Lo-Fi Version | Time is now: 4th June 2024 - 11:43 AM |
