Metal fatigue/stress marks near front subframe mount?, Argh. Good frame shop in MD just in case? |
ghuff |
Aug 9 2009, 02:05 PM
This is certainly not what I expected down here. Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region |
Bear with me I am going to get pictures, but I have what looks like metal fatigue. There was some cracked paint and surface rust starting on the drivers side rear control arm mounting point.
I think it may be from curbing in the past. It does not appear the front subframe mount was pulled out of alignment at all which is very odd, however the torsion bar adjustment is way off side to side..... Does anyone have a list of measurements for the front end? I want to make sure nothing is tweaked and if so, the car needs to go to the frame shop now then I can be sure it is straight. I suppose a 100% straightedge between the two rear mounting points would allow me to see if it were true heightwise.... The welds and undercoating on the tab that holds the bolt/threads are fine. It is just near the 90 degree sheetmetal tab that holds the rubber brake line to the unibody where it joins the steel. |
roadster fan |
Aug 12 2009, 08:52 PM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
I agree with Rich, strip the area to bare metal to make a better assessment. The link below is for a reinforcement piece for the sway bar that some cars have in that area but you could modify or use as is to strengthen that area after the repair is done. Hope this helps,
Jim Engman swaybar reinforcement |
Lo-Fi Version | Time is now: 10th June 2024 - 04:45 AM |
