| schreiber |
Aug 1 2009, 06:14 PM
Member ![]() ![]() Group: Members Posts: 137 Joined: 26-June 07 From: Huntsville, AL Member No.: 7,843 Region Association: South East States |
In this thread: Show pictures of your dual Weber setups. The more detail, the better.
| jmill |
Aug 16 2009, 10:58 AM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
The issue is that the bar between the linkage and the carb butterfly lever is at an angle. In fact, they are at slightly different angles. If you use the provided holes in the linkage arms, you will not get a 90 degree drop on either side, and the carbs don't stay perfectly synched through the rev range. Zach There is alot of talk about getting a 90 degree drop. I hate to say this but it'll never happen. You might be able to get 90 degrees at one throttle position but thats it. The hex bar spins in an arc and your looking for a right angle. You can't get there from here. Whats important is that both linkage arms are the same length and at the same angle relative to one another. That way the arm travels the same distance on either side. If you get that correct the carbs will stay synced through the entire range. |
schreiber Show me your dual carburetors setup Aug 1 2009, 06:14 PM
tat2dphreak this is how a bad setup looks... unfortunately, it... Aug 1 2009, 06:18 PM
Scott Schroeder mine ... Aug 1 2009, 07:25 PM
r_towle
mine ...
Scott,
I know this is a pain to do, bu... Aug 2 2009, 01:07 PM
MDG here's my dual webers :)
Aug 1 2009, 08:22 PM
zymurgist
I see what you... Aug 2 2009, 09:11 AM
MDG
I see what you did there. :driving:
What . . ... Aug 2 2009, 11:00 AM
craig downs Here some dual Dells
Aug 2 2009, 01:03 AM
schreiber
I'm interested in seeing these type linkage ... Aug 14 2009, 10:15 PM
pilothyer
I'm interested in seeing these type linkage... Aug 18 2009, 08:19 AM
tat2dphreak
[quote name='schreiber' post='1203045' date='Aug ... Aug 18 2009, 10:55 AM
t collins My Dells Aug 2 2009, 10:18 AM
Vacca Rabite
My Dells
How did you do this? Drill and tap the... Aug 2 2009, 02:39 PM
r_towle
My Dells
How did you do this? Drill and tap th... Aug 2 2009, 03:19 PM
Vacca Rabite
How did you do this? Drill and tap the arms?
I... Aug 2 2009, 09:14 PM
t collins
[quote name='r_towle' post='1198429' date='Aug 2 ... Aug 3 2009, 05:23 AM
t collins
My Dells
How did you do this? Drill and tap th... Aug 2 2009, 06:39 PM
rfuerst911sc Here are mine. :D Aug 2 2009, 01:22 PM
J P Stein Hee.hee, I can play. Real carbs have 3 throats. :D Aug 2 2009, 01:50 PM
r_towle
Hee.hee, I can play. Real carbs have 3 throats. :... Aug 2 2009, 03:20 PM
J P Stein
Hee.hee, I can play. Real carbs have 3 throats. ... Aug 2 2009, 09:01 PM
zx-niner Here's a before and after.
Aug 2 2009, 02:21 PM
carr914 RE: Show me your dual carburetors setup Aug 2 2009, 08:37 PM
carr914 RE: Show me your dual carburetors setup Aug 2 2009, 08:39 PM
puff adder 50's Aug 2 2009, 08:48 PM
racerbvd RE: Show me your dual carburetors setup Aug 2 2009, 09:21 PM
carr914 Byron, What are those Dizzy's you've got o... Aug 2 2009, 09:29 PM
racerbvd
Byron, What are those Dizzy's you've got ... Aug 2 2009, 09:34 PM
neil30076
In this thread: Show pictures of your dual Weber ... Aug 3 2009, 10:13 AM
Kargeek Dells with reversed CB crossbar linkage. Aug 3 2009, 01:28 PM
naro914 PMO's in Huey (now in Papa Smurf) Aug 3 2009, 04:56 PM
Mark Henry Cargeeks is the best linkage so far, but still a b... Aug 5 2009, 11:39 AM
martinef1963 This car ran for about 5-minutes after the engine ... Aug 16 2009, 06:11 AM
tat2dphreak
This car ran for about 5-minutes after the engine... Aug 16 2009, 09:10 AM
lotus_65 link
someone here makes a nice pivot linkage I... Aug 16 2009, 10:29 AM
jaxdream I believe that is called the sidewinder linkage ki... Aug 16 2009, 11:37 PM
Dominic Picture of my DTM bell crank linkage from Aircoole... Aug 18 2009, 08:36 AM
lotus_65
Picture of my DTM bell crank linkage from Aircool... Aug 18 2009, 06:46 PM
Cevan CIP1 linkage
Aug 18 2009, 09:51 AM
pilothyer Hi Wayne......I believe that was a pair of Weber 3... Aug 18 2009, 01:03 PM
tat2dphreak ahh, ok. Aug 18 2009, 01:17 PM
r_towle Take a look at some artwork here.
http://www.yuni... Aug 18 2009, 02:36 PM
Mr.Nobody Bump, because I want to see more peoples setups.
... Apr 21 2016, 06:07 PM
ThePaintedMan This is going to sound like a total dick comment, ... Apr 21 2016, 06:36 PM
Mr.Nobody
This is going to sound like a total dick comment,... Apr 21 2016, 11:03 PM
bretth How about my Zeniths just because. Hope to put the... Apr 21 2016, 07:46 PM
poorsche914 NOS 44IDF Webers with Raby Sync-Link
:driving: Apr 21 2016, 09:23 PM
raw1298 Not sure of brand, but it was free. :D Apr 21 2016, 09:52 PM
Elliot Cannon No play in the linkage. Both throttles open to wo... Apr 21 2016, 11:47 PM
era vulgaris DRLA40'S on a 2270 Apr 22 2016, 12:33 PM
Starlack OK
here is a Picture of my Engine with Weber Carb... Apr 22 2016, 12:57 PM
MarkV RE: Show me your dual carburetors setup Apr 22 2016, 02:29 PM
jacquot dual weber 44 idf, overall
throttle cable from... Apr 25 2016, 01:36 PM
forrestkhaag /The beauty of this system is simplicity and three... Apr 25 2016, 02:13 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th October 2026 - 11:53 PM |
