> Steve's unending Progress thread, Air compressor setup recommendations
stephenaki
post Jul 5 2008, 04:39 AM
Can I get this one dad??
OK, this will be the thread that I keep updated as I make progress. I showed up at 0800 at Christoph's place and he was ready for me with a not so glamorous chunk of metal that is my cars heart and soul.
With a little assistance, we loaded it into my Toyota Sienna, not quite I envisioned a mini-van for, and I was headed back to the house. Upon getting home I had to first make coffee then clear out some space in my tiny German garage. So that everyone has a frame of reference to the area that I am working in I have enclosed this lovely 4x6 glossy of my garage in Germany.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747638.1.jpg)
And, for those of you not familiar with the Toyota Sienna, a shot of the engine in the back of the van. There's a lot of room back there for the motor but, it is awkward to get in and out of when loading a motor.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.2.jpg)
Now to summarize what was accomplished on the 4th of July, engine brought home, tin, impeller and housing, exhaust, cylinder head and cylinders removed. I had difficulty removing the impeller hub. OK, I didn't get it removed, will need a puller and I don't have one unless anyone can give me any ideas how to get it off without a puller.
Now for the requisite pictures of the motor unmolested.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.3.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747640.4.jpg)
Now based on the initial tear down two problems presented it self first the primary issue with a lack of compression...HOLY SHIT!!! Here is what I found.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747641.5.jpg)
(IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif)
Now the cylnder itself was not pitted, it had a build up of corrosion but otherwise in good condition. So I was thinking, maybe I can just clean hone and replace the piston. Well that thought went out the window when I pulled the cylinder directly opposite to it. As you can see by the photo, problem #2.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.6.jpg)
More importantly, where did that piece of metal go? An initial look behind the piston shows a knick in the inner portion of the crankcase.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.7.jpg)
I will see if there is more significant damage when I split the case; so it begins and were off to a rocket start here at the 914 follies! Stay tuned for the next exciting episode of "never buy a car sight unseen" later in the week! (IMG:style_emoticons/default/happy11.gif)
Gonna go shower and start working on the motor some more. Plan is to have it completely torn down befor the end of this weekend. I will load up some pictures to my photo bucket album and post the link a bit later.
stephenaki
post Aug 14 2009, 02:33 PM
So, I took the time to replace all the O rings on the #1 and 2 cylinders today. When everyone says it is easy well, that is a matter of opinion. #3 and 4 side is bone dry, just the 1 and 2 cylinders that had oil leaking from what I could tell.
Since I wasn't sure which one, I replaced all the O rings. 4 hours later I had it started and idling up on the lift. I didn't see any oil form under the cylinder head as I did before and I let her idle for at least 10 minutes. I did see oil forming on the bottom front and rear seam of the crankcase though. So maybe I didn't seal the crankcase as well as I thought? Can I through on any type of sealant that over the seams that will keep her from leaking?
The oil is still hitting the exhaust when I stop and smoking and I have an exhaust leak in the number 1 cylinder. I will put her up on the lift again later and see what I can figure out.
It looks as if I'll be keeping the car, I had put it up for sale on 914freunde.de but haven't had any interest and truthfully, I don't think I can sell her as long as she has the oil leak problem. Unlike the PO, I have a hard time passing a problem off to someone else so will probably pull the ad.
What I really need is a weekend where I can drop the motor and check both seals to make sure they aren't leaking. I have two new seals that I got when Christoph also ordered some gaskets for me.
If anyone has some ideas on sealling the seams without cracking open the crankcase again I am all ears!
Bleyseng
post Aug 17 2009, 01:51 AM
Aircooled Baby!
QUOTE(stephenaki @ Aug 14 2009, 01:33 PM) *
rear crankcase seam leaks ususally are the rear main oil seal leaking past the flywheel sometimes the sealing surface on the flywheel is scored creating a leak.
I was just in Stuttgart to see the Porsche Museum!
stephenaki   Steve's unending Progress thread   Jul 5 2008, 04:39 AM
Gustl   Gonna go shower and start working on the motor so...   Jul 5 2008, 06:18 AM
hcdmueller   This whole scene looks very familiar. Your garage...   Jul 5 2008, 07:04 AM
Gustl   Gustl, I can't wait to see pictures from Aust...   Jul 6 2008, 06:49 AM
Vacca Rabite   I bet you will find all that metal in the sump whe...   Jul 5 2008, 08:59 AM
ericread   Get serious. With a bit of Mother's, it'l...   Jul 5 2008, 02:09 PM
stephenaki   OK, so I didn't get as much done today as I wa...   Jul 5 2008, 03:23 PM
Gustl   Gustl, Sorry I didn't make it to Toni's s...   Jul 6 2008, 06:51 AM
Dave_Darling   Impeller hub: Get some fender washers or other la...   Jul 5 2008, 10:59 PM
stephenaki   Impeller hub: Get some fender washers or other l...   Jul 6 2008, 01:42 AM
stephenaki   Case is split! :D So after we ran around thi...   Jul 6 2008, 01:29 PM
!   If you're married to that motor, get LN Engine...   Jul 6 2008, 01:55 PM
stephenaki   If you're married to that motor, get LN Engin...   Jul 6 2008, 02:51 PM
hcdmueller   New 96mm pistons and cylinders are available at Ja...   Jul 6 2008, 05:04 PM
Jake Raby   New 96mm pistons and cylinders are available at J...   Jul 6 2008, 06:02 PM
stephenaki   New 96mm pistons and cylinders are available at ...   Jul 6 2008, 10:50 PM
ericread   I just need her running before it gets cold this ...   Jul 7 2008, 03:31 PM
Dr Evil   [quote name='Jake Raby' post='1053123' date='Jul ...   Jul 7 2008, 05:02 PM
rick 918-S   [quote name='Jake Raby' post='1053123' date='Jul ...   Jul 7 2008, 07:10 PM
stephenaki   OK, in order to do the proper conversion that Ja...   Jul 8 2008, 01:06 AM
Smitty911   OK, in order to do the proper conversion that J...   Jul 8 2008, 09:58 PM
stephenaki   http://dprmachine.com/Html%20Files/cranks_type_4...   Jul 9 2008, 01:00 AM
ME733   [quote name='Jake Raby' post='1053123' date='Jul ...   Aug 16 2009, 06:32 AM
r_towle   I agree. what parts do you need? I am sure we all...   Jul 7 2008, 05:37 PM
kwales   Buy a new one- dstributor gears are cheep. They m...   Jul 7 2008, 07:50 PM
stephenaki   OK, edumacate me everyone. I looked at the site t...   Jul 9 2008, 02:06 AM
stephenaki   Two things to update today; first is status of cra...   Jul 13 2008, 03:28 PM
stephenaki   OK, so after doing some studying yesterday morning...   Jul 20 2008, 09:44 AM
hcdmueller   Glad to see you are making progress. I feel your ...   Jul 20 2008, 06:17 PM
r_towle   To answer your question regarding the valve guides...   Jul 20 2008, 08:12 PM
stephenaki   To answer your question regarding the valve guide...   Jul 21 2008, 02:12 AM
Smitty911   To answer your question regarding the valve guid...   Jul 21 2008, 02:34 PM
stephenaki   Well, the crankshaft and rods came in last week Tu...   Aug 9 2008, 09:19 AM
ThinAir   This is a great thread. I really appreciate all t...   Aug 9 2008, 04:36 PM
stephenaki   This is a great thread. I really appreciate all ...   Sep 10 2008, 01:15 PM
stephenaki   OK, I'm back from my adventures in the Republi...   Nov 13 2008, 07:09 AM
stephenaki   OK, Tin's back along with the fan housing and ...   Dec 9 2008, 06:59 AM
stephenaki   OK, I think my car has a curse on it or something ...   Dec 15 2008, 07:09 AM
Dave_Darling   Sounds like you got 1.7/1.8 bearings instead of th...   Dec 15 2008, 09:41 AM
stephenaki   Sounds like you got 1.7/1.8 bearings instead of t...   Dec 15 2008, 12:39 PM
stephenaki   Called Christoph today, again I need to reiterate ...   Jan 8 2009, 09:45 AM
stephenaki   The bearings are in and they fit! The crank is...   Jan 15 2009, 08:40 AM
stephenaki   Finally got around to getting some pictures of the...   Jan 16 2009, 05:38 AM
stephenaki   Progress is being made, slow, deliberate and educa...   Jan 25 2009, 01:42 PM
stephenaki   OK, so, after discussion and reading on deck heigh...   Feb 15 2009, 10:57 AM
stephenaki   Well, did you ever get the feeling the automotive ...   May 7 2009, 11:14 AM
stephenaki   Well, after a couple of weeks and a motorcycle tri...   Jun 10 2009, 11:20 AM
stephenaki   Well, after a full day the motor is 98% complete...   Jun 12 2009, 01:49 PM
stephenaki   Hot damn! After almost about a year and a half...   Jul 10 2009, 11:37 AM
Gustl   Hot damn! After almost about a year and a hal...   Jul 10 2009, 01:06 PM
stephenaki   Hot damn! After almost about a year and a ha...   Jul 11 2009, 08:01 AM
Gustl   I need to call him again on Monday as I forgot to...   Jul 11 2009, 08:48 AM
stephenaki   I need to call him again on Monday as I forgot t...   Jul 11 2009, 01:37 PM
roadster fan   :trophy: Love your persistence! Hope you ha...   Jul 12 2009, 04:50 PM
hcdmueller   Congratulations! I am really jealous. I got ...   Jul 12 2009, 08:11 PM
stephenaki   Well ladies and gentlemen, it's home. :Qarl: ...   Jul 17 2009, 08:09 AM
stephenaki   OK, I got a chance to check some things on the car...   Jul 19 2009, 08:19 AM
stephenaki   OK, I now know why the cost of living is so expens...   Jul 21 2009, 03:48 AM
Gustl   oh man, I'm really sorry about this :( I k...   Jul 21 2009, 04:17 AM
stephenaki   oh man, I'm really sorry about this :( I ...   Jul 21 2009, 04:19 AM
Cupomeat   Damn, This is a shame about the bill total and the...   Jul 21 2009, 08:35 AM
stephenaki   Damn, This is a shame about the bill total and th...   Jul 22 2009, 04:33 AM
stephenaki   So, I talked to household 6, for those of you that...   Jul 22 2009, 05:39 AM
hcdmueller   Sorry to hear this. I got back from my deployment...   Jul 22 2009, 05:55 AM
stephenaki   Sorry to hear this. I got back from my deploymen...   Jul 22 2009, 06:41 AM
stephenaki   OK, so I put her on the lift today to find the oil...   Jul 25 2009, 08:19 AM
Dave_Darling   Pushrod tubes: Pull the tubes halfway out of the ...   Jul 25 2009, 03:04 PM
stephenaki   Pushrod tubes: Pull the tubes halfway out of the...   Jul 27 2009, 06:41 AM
stephenaki   So, I took the time to replace all the O rings on ...   Aug 14 2009, 02:33 PM
Bleyseng   So, I took the time to replace all the O rings on...   Aug 17 2009, 01:51 AM
stephenaki   rear crankcase seam leaks ususally are the rear ...   Aug 17 2009, 10:53 AM
stephenaki   OK, the new windshield is in and trim is on, shoul...   Sep 23 2009, 01:09 PM
stephenaki   So, I was able to get a floor jack and some stands...   Sep 28 2009, 01:10 PM
stugray   HA HA! when I read the title of this thread I...   Sep 30 2009, 10:40 PM
stephenaki   2 hours my ass! :angry: So I found a CV join...   Sep 29 2009, 02:36 PM
stephenaki   OK, had to pull the carbs in order to get the axle...   Sep 30 2009, 12:20 PM
Dave_Darling   You're using the same method I've used to ...   Sep 30 2009, 11:02 PM
stephenaki   You're using the same method I've used to...   Oct 1 2009, 01:14 AM
Dave_Darling   I don't think I did, but I probably should hav...   Oct 1 2009, 07:01 PM
stephenaki   I don't think I did, but I probably should ha...   Oct 2 2009, 07:22 AM
stephenaki   Well, necessity being the mother of invention, I w...   Oct 2 2009, 01:42 PM
Dave_Darling   Only one #15 per side. It goes between the mount ...   Oct 2 2009, 11:01 PM
stephenaki   Only one #15 per side. It goes between the mount...   Oct 3 2009, 01:25 PM
stephenaki   Well, today didn't quite go as planned, I got ...   Oct 4 2009, 09:45 AM
stephenaki   IT'S ALIVE!!!! Well, kinda, f...   Oct 10 2009, 12:10 PM
stephenaki   So, I've evidently I have bronchitis, great. ...   Oct 15 2009, 11:51 AM
stephenaki   OK, so today was a rather dismal day in Germany, c...   Oct 17 2009, 12:57 PM
hcdmueller   Is your pulley for the cooling flap cable torqued ...   Oct 17 2009, 01:51 PM
stephenaki   Is your pulley for the cooling flap cable torqued...   Oct 17 2009, 02:07 PM
stephenaki   OK, after a slow start this morning, I watched Mon...   Oct 18 2009, 10:52 AM
ILM914   just took my impeller hub off, if I hadn't put...   Oct 18 2009, 06:20 PM
stephenaki   just took my impeller hub off, if I hadn't pu...   Oct 19 2009, 01:29 AM
stephenaki   So what does one learn when they head out at 0645 ...   Oct 19 2009, 01:56 AM
Gint   1. oil tampon suggestions? Anyone ever rig someth...   Oct 19 2009, 08:37 AM
stephenaki   1. oil tampon suggestions? Anyone ever rig somet...   Oct 19 2009, 11:30 PM
stephenaki   Well, after a long Thanksgiving and some other thi...   Dec 19 2009, 10:24 AM
stephenaki   Well, the weather was warm enough for me to tackle...   Dec 31 2009, 08:14 AM
stephenaki   So, it's been snowing here since last Friday a...   Jan 12 2010, 01:15 AM
stephenaki   OK, phase 2 in this money pit and I need some help...   Jan 23 2010, 04:20 AM
Racer Chris   I have a 1.7 machined for a 2.0; how much be...   Jan 23 2010, 05:58 AM
5 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 22nd August 2025 - 11:45 AM
