| montoya 73 2.0 |
Aug 16 2009, 12:37 AM
Lack of consideration to others, and Selfish! ![]() ![]() ![]() Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
I know the steps:
- take off 4 bolts tranny to engine - unhook 2 tranny mounts in the back - take off 2 axels - take off shift linkage - remove muffler/muffler hanger - remove starter and wire to reverse switch - remove speedo cable - remove clutch cable - disconnect tranny ground strap (EDIT: Not necessarliy in correct order) But whats the best way to remove without damaging: Shift linkage (remove the Spam Can without damaging the clamp), speedo cable & clutch cable? A few pictures of what I'm dealing with... ![]() "Spam Can" ![]() Attached image(s)
| Dr Evil |
Aug 17 2009, 06:30 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,044 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
The yellow arrow is the rear conical screw. There is one in the front that needs to be removed as well. The whole outer linkage needs to be removed to pull the tranny without issue. The blue arrow shows the end of the rod that you push forward while you pull the cup rearward. Easy (IMG:style_emoticons/default/wink.gif)
| montoya 73 2.0 |
Aug 17 2009, 11:04 PM
The yellow arrow is the rear conical screw. There is one in the front that needs to be removed as well. The whole outer linkage needs to be removed to pull the tranny without issue. The blue arrow shows the end of the rod that you push forward while you pull the cup rearward. Easy (IMG:style_emoticons/default/wink.gif) was wondering why the rod wouldn't back out of the case? So to the front I go! Thanks Doc. Oh, them triple square bolts are a real pain. I think I may have to destroy them to get them out. I got two out before the tool started to spin out. Vice grips should work good? Uh Doc, I'll buy two sets of bolts instead of one. |
montoya 73 2.0 Removing Transmission, Need advice and help... Aug 16 2009, 12:37 AM
Mark Henry Big nut on speedo drive, do it carefully and don... Aug 16 2009, 01:04 AM
Dr Evil 4 bolts tranny to engine are LAST, unless you want... Aug 16 2009, 01:31 AM
montoya 73 2.0 Thank you! Aug 16 2009, 11:54 AM
Bristol I just did this job last week (bad seal on trans s... Aug 17 2009, 11:32 AM
montoya 73 2.0 Where and what exactly do I remove? Aug 17 2009, 02:15 PM
Cupomeat Ok, at the end of the shift rod, behind the bushin... Aug 17 2009, 02:20 PM
montoya 73 2.0
Ok, at the end of the shift rod, behind the bushi... Aug 17 2009, 02:57 PM
Dr Evil PM and remind me. I will be making some this week ... Aug 17 2009, 11:12 PM
montoya 73 2.0 I believe this sending unit has to be removed but ... Aug 23 2009, 04:44 PM
Dave_Darling Just unplug it; the wires have bullet-shaped conne... Aug 23 2009, 04:55 PM
montoya 73 2.0
Just unplug it; the wires have bullet-shaped conn... Aug 23 2009, 04:56 PM
montoya 73 2.0 Pulled out the Tranny the next day (Monday). But t... Sep 1 2009, 11:11 PM
Dr Evil Oh Shit! That is totally OK. Sep 1 2009, 11:31 PM
montoya 73 2.0 Okay cool! Just checking.
Quick question, Is ... Sep 1 2009, 11:55 PM
Dr Evil Sure, with enough money you can do anything. 2nd i... Sep 2 2009, 12:18 AM
montoya 73 2.0
Sure, with enough money you can do anything. 2nd ... Sep 2 2009, 04:49 PM
jimkelly rpm's high - you want to drive in the gear tha... Sep 2 2009, 09:51 AM
montoya 73 2.0 Wasn't thinking that far in advance, But i gue... Sep 2 2009, 04:46 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd November 2026 - 11:22 AM |
