> Removing Transmission, Need advice and help..., Never pulled one before...
montoya 73 2.0
post Aug 16 2009, 12:37 AM
Lack of consideration to others, and Selfish!
I know the steps:
- take off 4 bolts tranny to engine
- unhook 2 tranny mounts in the back
- take off 2 axels
- take off shift linkage
- remove muffler/muffler hanger
- remove starter and wire to reverse switch
- remove speedo cable
- remove clutch cable
- disconnect tranny ground strap
(EDIT: Not necessarliy in correct order)
But whats the best way to remove without damaging:
Shift linkage (remove the Spam Can without damaging the clamp), speedo cable & clutch cable?
A few pictures of what I'm dealing with...
"Spam Can"
Dr Evil
post Aug 17 2009, 11:12 PM
Send me your transmission!
PM and remind me. I will be making some this week I hope.
montoya 73 2.0   Removing Transmission, Need advice and help...   Aug 16 2009, 12:37 AM
Mark Henry   Big nut on speedo drive, do it carefully and don...   Aug 16 2009, 01:04 AM
Dr Evil   4 bolts tranny to engine are LAST, unless you want...   Aug 16 2009, 01:31 AM
montoya 73 2.0   Thank you!   Aug 16 2009, 11:54 AM
Bristol   I just did this job last week (bad seal on trans s...   Aug 17 2009, 11:32 AM
montoya 73 2.0   Where and what exactly do I remove?   Aug 17 2009, 02:15 PM
Cupomeat   Ok, at the end of the shift rod, behind the bushin...   Aug 17 2009, 02:20 PM
montoya 73 2.0   Ok, at the end of the shift rod, behind the bushi...   Aug 17 2009, 02:57 PM
Dr Evil   The yellow arrow is the rear conical screw. There ...   Aug 17 2009, 06:30 PM
montoya 73 2.0   The yellow arrow is the rear conical screw. There...   Aug 17 2009, 11:04 PM
Dr Evil   PM and remind me. I will be making some this week ...   Aug 17 2009, 11:12 PM
montoya 73 2.0   I believe this sending unit has to be removed but ...   Aug 23 2009, 04:44 PM
Dave_Darling   Just unplug it; the wires have bullet-shaped conne...   Aug 23 2009, 04:55 PM
montoya 73 2.0   Just unplug it; the wires have bullet-shaped conn...   Aug 23 2009, 04:56 PM
montoya 73 2.0   Pulled out the Tranny the next day (Monday). But t...   Sep 1 2009, 11:11 PM
Dr Evil   Oh Shit! That is totally OK.   Sep 1 2009, 11:31 PM
montoya 73 2.0   Okay cool! Just checking. Quick question, Is ...   Sep 1 2009, 11:55 PM
Dr Evil   Sure, with enough money you can do anything. 2nd i...   Sep 2 2009, 12:18 AM
montoya 73 2.0   Sure, with enough money you can do anything. 2nd ...   Sep 2 2009, 04:49 PM
jimkelly   rpm's high - you want to drive in the gear tha...   Sep 2 2009, 09:51 AM
montoya 73 2.0   Wasn't thinking that far in advance, But i gue...   Sep 2 2009, 04:46 PM
- Lo-Fi Version Time is now: 3rd November 2026 - 11:22 AM
