| tradisrad |
Aug 21 2009, 09:03 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I purchased Elephant Racing poly bronze bushings for the rear. I spent a ton of time and several broken drill bits removing the stock rubber from one trailing arm.
This task was a big PIA. Is there another way, for those who don't have a 20-ton press, to remove these bushings? Any advice is appreciated. |
| J P Stein |
Aug 21 2009, 12:02 PM
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Fire is your friend....unless you live in CA. (IMG:style_emoticons/default/biggrin.gif)
tradisrad Removing trailing arm bushings Aug 21 2009, 09:03 AM
jaxdream Have you tryed heating with a propane tourch to me... Aug 21 2009, 09:10 AM
tradisrad yes, I applied heat and had them smoking. Worked g... Aug 21 2009, 09:25 AM
McMark Here's what I do. They come out smoothly. No... Aug 21 2009, 11:19 AM
kconway
Here's what I do. They come out smoothly. N... Aug 21 2009, 12:14 PM
jaxdream
Here's what I do. They come out smoothly. N... Aug 21 2009, 12:21 PM
tradisrad McMark, thanks I'll give that a try! I... Aug 21 2009, 11:53 AM
ChrisNPDrider Yes, they are a pain to get out! I found that ... Aug 21 2009, 12:02 PM
sean_v8_914 a press works best Aug 21 2009, 12:15 PM
tradisrad McMark: :worship: You saved me hours on the second... Aug 22 2009, 09:50 AM
SKL1 Now what?
Pushing out the hubs with a 12 ton pre... Mar 24 2013, 06:37 PM
bandjoey WAtch this for the hubs and bearings:
http://www.... Mar 24 2013, 06:42 PM
SKL1 Figured Eric would have the answer!
Bet I... Mar 24 2013, 07:23 PM
SKL1 Installing rear bearing video won't work- hope... Mar 24 2013, 07:35 PM
Eric_Shea Do you have a press? Mar 24 2013, 07:53 PM
SKL1 Yep a 12 ton HF that looks like the one in one of ... Mar 25 2013, 05:41 AM
02loftsmoor I looks like you came from cold country, is there ... Mar 25 2013, 09:36 AM
Eric_Shea
I simply press the shafts out. As follows:
1. ... Mar 25 2013, 04:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th November 2026 - 05:01 AM |
