> Removing trailing arm bushings, what a pain
tradisrad
post Aug 21 2009, 09:03 AM
I purchased Elephant Racing poly bronze bushings for the rear. I spent a ton of time and several broken drill bits removing the stock rubber from one trailing arm.
This task was a big PIA.
Is there another way, for those who don't have a 20-ton press, to remove these bushings? Any advice is appreciated.
tradisrad
post Aug 22 2009, 09:50 AM
McMark: (IMG:style_emoticons/default/pray.gif) You saved me hours on the second trailing arm. So why does Chuck at Elephant recomment drilling the bushings out?
To anyone doing this job. DO NOT DRILL, use McMarks method. Minutes compared hours...
tradisrad   Removing trailing arm bushings   Aug 21 2009, 09:03 AM
jaxdream   Have you tryed heating with a propane tourch to me...   Aug 21 2009, 09:10 AM
tradisrad   yes, I applied heat and had them smoking. Worked g...   Aug 21 2009, 09:25 AM
McMark   Here's what I do. They come out smoothly. No...   Aug 21 2009, 11:19 AM
kconway   Here's what I do. They come out smoothly. N...   Aug 21 2009, 12:14 PM
jaxdream   Here's what I do. They come out smoothly. N...   Aug 21 2009, 12:21 PM
tradisrad   McMark, thanks I'll give that a try! I...   Aug 21 2009, 11:53 AM
J P Stein   Fire is your friend....unless you live in CA. :D   Aug 21 2009, 12:02 PM
ChrisNPDrider   Yes, they are a pain to get out! I found that ...   Aug 21 2009, 12:02 PM
sean_v8_914   a press works best   Aug 21 2009, 12:15 PM
tradisrad   McMark: :worship: You saved me hours on the second...   Aug 22 2009, 09:50 AM
SKL1   Now what? Pushing out the hubs with a 12 ton pre...   Mar 24 2013, 06:37 PM
bandjoey   WAtch this for the hubs and bearings: http://www....   Mar 24 2013, 06:42 PM
SKL1   Figured Eric would have the answer! Bet I...   Mar 24 2013, 07:23 PM
SKL1   Installing rear bearing video won't work- hope...   Mar 24 2013, 07:35 PM
Eric_Shea   Do you have a press?   Mar 24 2013, 07:53 PM
SKL1   Yep a 12 ton HF that looks like the one in one of ...   Mar 25 2013, 05:41 AM
02loftsmoor   I looks like you came from cold country, is there ...   Mar 25 2013, 09:36 AM
Eric_Shea   I simply press the shafts out. As follows: 1. ...   Mar 25 2013, 04:05 PM
- Lo-Fi Version Time is now: 10th November 2026 - 05:01 AM
