silverteener |
Member ![]() ![]() Group: Members Posts: 214 Joined: 9-August 05 From: East Moline, IL Member No.: 4,566 ![]() |
We'll..
I got another hazard switch today and still have no turn signals. I have replaced the turn signal lever and put a new relay in. I also checked the light bulbs and they are 1157's. I found a ground under the dash above the fuse box and it is tight. This thing is really starting a piss me off. I'm thinking it's going back on jackstands til next year. I'm at a lose and there is no one around here to take it too. Any more suggestions? It's a 72 that I would like to (IMG:style_emoticons/default/ar15.gif) right now! |
orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
get a diagram and trace power from the fuse up, wire by wire.
if your not familiar with this get a good test light (for visual), or better yet a volt meter (for acual voltage drop). ground and check your voltage (or test w/ light) at fuse (example 12.5v or lights up). locate where this wire go's to next. check the voltage or test with light. keep going wire by wire and component by component. note; make sure ALL the fuses are in and good. these cars do strange electrical things with fuse issues good luck (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 8th July 2025 - 09:47 PM |
