Starting A/C project, using "V" belt |
drive-ability |
Mar 27 2009, 07:26 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
As stated I am starting to look at what I need to do to build an A/C system for my 914.
Since my power steering seems to be working great I can move on to the next thing on the list.. I am using a "V" belt system and really don't want to change it over, besides the cost may be more than I want to spend. If someone knows a cheaper way to add a serpentine system let me know.. (I have a first generation SBC). My thought was to decide on a compressor and use the condenser, evaporator, dryer which go's with system.. I've looked into an electric compressor but I have enough amperage blasting through my car already and I don't know what voltage thy run on.. I may switch over to a electric water pump to free up space but I 'm not sure. suggestions welcome !!! |
computers4kids |
Aug 22 2009, 08:55 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I presume the upper bracket will be bolting to the head. I've been waiting till winter to install my setup because I didn't thing there was enough room to get to those bolts. Did you find otherwise? I have a first generation as well.
drive-ability |
Aug 22 2009, 05:27 PM
I presume the upper bracket will be bolting to the head. I've been waiting till winter to install my setup because I didn't thing there was enough room to get to those bolts. Did you find otherwise? I have a first generation as well. Here is another with the bracket installed, needs to have more holding it up. I just trying a few things on for size. The bracket wasn't hard to install, little tight but not bad. Things are going to take time, can't have the thing brake on my way to Washington State. I'm likely going there as soon as I have this bracket system worked out. I need to get some door bars and tie in the rear strut mounts in to stiffen it up more. (IMG:http://members.cox.net/altjamy/DSCN0996%20(Small).jpg) |
Lo-Fi Version | Time is now: 1st June 2024 - 08:01 PM |
