Fuel line 1975 914 2.0, Under the fuel tank |
ConeDodger |
Aug 22 2009, 06:14 PM
Apex killer! Group: Members Posts: 23,622 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I just did a search on this to figure out the hose sizes and best I can tell there are two or three different size hoses under the tank??? (IMG:style_emoticons/default/dry.gif) One from the tank to the filter, one from the filter to the pump, and at least one more size???
What are the appropriate sizes and lengths? (IMG:style_emoticons/default/blink.gif) |
detoxcowboy |
Aug 22 2009, 07:15 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
this is what you need cut to fit so it does not bind closed when you put the tank in.. if you pull the tank you can do a bit of measuring but leave the hoses off the tank nipples longer than you will need then cut them to fit from underneath after tank is re installed.. the tapered hose is for the filter to pump (also need to be trimmed a bit).. pelican parts..
N-020-281-1-M5021 7mm ID, 13mm OD, (quantity as needed, priced per meter) Brand: Contitech - Porsche [More Info] $10.75 13-31-1-469-781-M149 Fuel Hose, (8mm ID, 13mm OD) High Pressure, Priced Per Meter, As Needed Brand: Veritas [More Info] $9.75 914-356-525-00-M100 Tapered Fuel Hose For Connection at Fuel Filter, 914 1.7/1.8/2.0 (1970-74), Each [More Info] Brand: Genuine Porsche Fuel Filters [view in catalog] $23.00 |
Lo-Fi Version | Time is now: 16th June 2024 - 07:59 AM |
